| dknechtly |
Sep 16 2021, 04:41 PM
Yellow 914 ![]() ![]() Group: Members Posts: 71 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
I'm checking for a friend of mine. Looking for a Mahle piston for a 1970 2.2 911T. He said it has a number of 84v48. Might need a cylinder also. Just thought it might be worth shot checking with you guys. Thanks.
| 914Sixer |
Sep 17 2021, 05:59 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,514 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Partsgeek
Attached thumbnail(s) |
| Luke M |
Sep 17 2021, 06:06 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,555 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
I'm checking for a friend of mine. Looking for a Mahle piston for a 1970 2.2 911T. He said it has a number of 84v48. Might need a cylinder also. Just thought it might be worth shot checking with you guys. Thanks. I may have a 2.2T piston. I'll dig through my engine parts later today and post back here. What's the group size that you need? |
| dknechtly |
Sep 17 2021, 06:39 AM
Hmmm... group size... that's a good question. I'll have to check with him.
| dknechtly |
Sep 17 2021, 04:09 PM
Turns out he only needs a piston. He would buy piston and cyl if someone would rather not split them up. He broke the skirt on his. He's honing and putting in new rings on the whole engine. The piston just needs to have 84v48 on the bottom.
| Luke M |
Sep 17 2021, 05:57 PM
Good news I found the pistons here. The bad news is they are 2.0 E pistons so they will not work for you. Check over on Pelican parts or Samba.
| dknechtly |
Sep 18 2021, 09:49 AM
Thanks for checking.
| dknechtly |
Sep 21 2021, 05:20 AM
My friend found his piston. Ended up buying a whole set. Thanks for your help.
Lo-Fi Version | Time is now: 11th July 2026 - 02:21 PM |
