> Temperature Gauge Jumping, Is there a "quick fix"?
Rick986
post Sep 21 2021, 02:38 PM
0-60 in 14 seconds!
My console temp gauge either bounces all over the place or just stays in the red (even on a cold engine). Has anybody had this specific issue they sorted out previously? Thanks.
Replies(1 - 8)
dr914@autoatlanta.com
post Sep 21 2021, 02:39 PM
loose wire between the main harness and the sending unit underneath the engine
914Sixer
post Sep 22 2021, 01:10 PM
Sending wire is going open. Replace wire from sender to plug under battery with temporary wire. See if problem goes away.
Rick986
post Sep 22 2021, 05:00 PM
0-60 in 14 seconds!
QUOTE(dr914@autoatlanta.com @ Sep 21 2021, 02:39 PM) *
Hey George - where exactly is that "sending unit"? (your Tech Tips book is on its way!)
And did the other respondent essentially say the same thing? Is that "main harness" by the battery?
Thanks! - Rick
emerygt350
post Sep 22 2021, 05:03 PM
Right down by the drain plug and strainer.
914Sixer
post Sep 22 2021, 05:05 PM
Look on the bottom of engine. You can see where wire is. Wire plug in is under battery tray on engine shelf from main harness.
Rick986
post Sep 23 2021, 11:42 AM
0-60 in 14 seconds!
Thanks guys!
LefthandRev
post Sep 23 2021, 11:50 AM
Crazy. We're working on the same thing at the same time. Not sure how I didn't notice this before posting.
Rick986
post Sep 28 2021, 09:06 AM
0-60 in 14 seconds!
QUOTE(LefthandRev @ Sep 23 2021, 11:50 AM) *
Did you get yours fixed? I haven't checked it out yet. Going up on lift Friday. Thanks!
- Lo-Fi Version Time is now: 18th October 2026 - 11:42 AM
