> Mystery Tin, Please help identify
9**P-car
post Sep 21 2021, 03:55 PM
1975 2.0L
For my engine rebuild, I sent all my tin out for powder coating. After assembly, I have 2 pieces of tin that I can't find a home for. Thinking they might be related to the heat ducting, which I have not installed yet. Anyone have any ideas?
Here are some pics with different angles.
Replies(1 - 4)
rhodyguy
post Sep 21 2021, 03:59 PM
Warm air guides for late heat exchangers. They connect to the HEs and the case. The arched one is dr side.
9**P-car
post Sep 21 2021, 04:06 PM
1975 2.0L
QUOTE(rhodyguy @ Sep 21 2021, 03:59 PM) *
Thank you!
So I am backdating my exhaust to the early 2.0 heat exchangers, and getting rid of the '75 manifold/exchanger setup. Do you know if the early exchangers had similar warm air guides? If so, I'll have to post a WTB.
type47fan
post Sep 21 2021, 05:37 PM
It Looks Better In Person. . .
QUOTE(9**P-car @ Sep 21 2021, 03:06 PM) *
Thank you!
PM sent
rhodyguy
post Sep 21 2021, 06:25 PM
The driver's side differs. Side shift, the rear rod runs below the curve. Tail, the rod runs above. Pass side is common.
You should also have earlier L&R J tubes, L&R S shaped ducting and clamping pieces(914rubber has the seals you need for these), warm air elbows and the rear hanger. New fasteners.
- Lo-Fi Version Time is now: 29th September 2026 - 09:32 PM
