No Reverse, Won't go into reverse |
frankiec |
Oct 1 2021, 04:25 PM
Newbie Group: Members Posts: 2 Joined: 1-October 21 From: N. CA Member No.: 25,950 Region Association: Northern California |
My 901 side shifter recently lost reverse gear. I jacked up the car and had my wife sit in it to shift. I removed the dust/boot cover where the shift lever enters the tranny. I had her dry shift through the gears and when she was putting it in reverse I pushed on the bottom where it goes up to engage and it went up just a bit further and I could hear it click in. I lowered the car with the reverse engaged and started the car and it backed up. Without the it going all the way up and engaging no reverse. Going forward is fun but sometimes I need to go backward.
Thanks, Tom |
Shivers |
Oct 1 2021, 04:42 PM
Senior Member Group: Members Posts: 2,414 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Check for old worn bushings in the shift linkage, and loose lock down bolts
PanelBilly |
Oct 1 2021, 05:04 PM
914 Guru Group: Members Posts: 5,813 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Buy the Tangerine kits and make everything work the way it should. Watch my video on the install
rhodyguy |
Oct 1 2021, 05:07 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,088 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Rear ball cup bushing.
930cabman |
Oct 1 2021, 05:31 PM
Advanced Member Group: Members Posts: 3,134 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
jcd914 |
Oct 1 2021, 05:47 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Check the set screws at each end of the shift rod, then tend to come loose.
I just had a similar experience except it quickly went from trouble getting reverse to only having 2nd & 3rd. Initially it took a couple tries to get reverse and the I tried a little harder and it got a lot worse. It was the shift coupler bushing up by the firewall. When I pulled the boot loose most of the bushings fell out as crumbs & dust. You have to press the pin out of the coupling to get the new bushings in. I use a vise and some socket to press the pin out and back in. Use new set screws or blue locktite. Jim |
windforfun |
Oct 2 2021, 12:07 PM
Senior Member Group: Members Posts: 1,827 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Check the set screws at each end of the shift rod, then tend to come loose. I just had a similar experience except it quickly went from trouble getting reverse to only having 2nd & 3rd. Initially it took a couple tries to get reverse and the I tried a little harder and it got a lot worse. It was the shift coupler bushing up by the firewall. When I pulled the boot loose most of the bushings fell out as crumbs & dust. You have to press the pin out of the coupling to get the new bushings in. I use a vise and some socket to press the pin out and back in. Use new set screws or blue locktite. Jim The wall of the new firewall bushing can be cut at 45 degrees & than slipped over the shift rod without removing it. The bushing is then pushed into the firewall. |
Lo-Fi Version | Time is now: 4th June 2024 - 10:05 AM |
