Pinout values for 74 1.8 ECU |
L-Jet914 |
Oct 21 2021, 09:56 PM
Member Group: Members Posts: 253 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I recently bought a used 74 1.8 ECU for a backup part if needed. I was wondering if anyone has any pinout values so I can test the ECU to see if it is good. Thank you in advance.
L-Jet914 |
Oct 24 2021, 04:15 PM
bump
timothy_nd28 |
Oct 25 2021, 10:56 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Not sure what you are asking here. Are you asking for resistance values for each ECU pin, or are you using a curve tracer? Either method wouldn't tell you much about the integrity of the ECU.
The fastest way would be a go/no go test by just throwing it into the car and trying it out to see if it works. To bench test, you would need to bring power and grounds to certain pins. Also find a way to simulate high ignition voltage for the ECU to read, along with a dummy load for the fuel injectors while observing timing of each pulse with a 4 channel O scope. Not to mention providing certain resistances for the AFM and CHT sensor, it would be problematic to bench test the ECU. Pretty sure they have a wheel barrel type test machine that would do this all for you, but again, much easier to throw the spare ECU in the car to see if it works. |
lesorubcheek |
Oct 25 2021, 11:22 AM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
StarBear |
Oct 25 2021, 02:51 PM
Senior Member Group: Members Posts: 1,909 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Been looking for someone with test equipment for an 1.8 ECU. Someone (Jeff B?) has the 1.7 and 2.0 I think. Special test equipment IIRC. (IMG:style_emoticons/default/confused24.gif)
JeffBowlsby |
Oct 25 2021, 03:10 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have the EFI Associates testers for both MPC and AFC FI systems. Unable to test the ECU by itself, these testers require the ECU in the car with the rest of the FI system, where the testing cable is interposed at the ECU connection with the EFI harness, and the ECU (and the rest of the FI system) is tested in situ. Individual function blocks of the ECU can be verified using this tester in this way.
Attached image(s) |
L-Jet914 |
Oct 25 2021, 08:47 PM
So I guess quickest way to test the ECU I purchased is to plug it in and see if the car runs?
Lo-Fi Version | Time is now: 7th June 2024 - 12:44 AM |
