> Fuel tank, Mesh strainer removal
EJP914
post Oct 24 2021, 06:05 PM
Going to have my gas tank cleaned and coated. I'm guessing the silver colored washer shown in the picture is the bottom of the strainer / screen? How to remove it? Its stuck in there pretty good. Can I pry out with a small screwdriver or grab with pliers and pull. Didn't want to get too crazy on it and damage the adjacent threads.
Any other suggestions are appreciated. Thanks.
EdAttached Image
Replies(1 - 4)
914werke
post Oct 24 2021, 07:14 PM
Unless you are trying to save it grab it with anything & pull, Id use a utility knife to get under it
post Oct 24 2021, 09:52 PM
They melt quickly when heat is applied with a butane torch. But since it may harbor fumes you'd need fill the tank with water first. (IMG:style_emoticons/default/beerchug.gif)
Tdskip
post Oct 25 2021, 05:48 AM
Thin screwdriver under the lip to pry it free will work as well.
jrmdir
post Oct 25 2021, 06:34 AM
They're not expensive and I assume you're getting a new one for your clean tank, so pry away. My old one came loose pretty easily. You could also try a screw extractor to break the ring loose.
Ron
- Lo-Fi Version Time is now: 16th June 2024 - 08:54 PM
