wiper blades |
wiper blades |
Medtner3 |
Nov 19 2021, 07:58 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Any suggestions as to what the correct period wiper blades would be for 1974 914
76-914 |
Nov 20 2021, 09:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
12" , IIRC. (IMG:style_emoticons/default/beerchug.gif)
bdstone914 |
Nov 20 2021, 09:41 AM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Any suggestions as to what the correct period wiper blades would be for 1974 914 @Medtner3 @76-914 They are 13". Just had to buy some. Be aware there are two versions. The original wiper arms were 7.5mm width. Replacements are 9mm. The attachment piece on the blade has to match the arm. Pelican has both. Local auto parts stores are not likely to have the 7.5mm width. |
NARP74 |
Nov 20 2021, 12:46 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Any suggestions as to what the correct period wiper blades would be for 1974 914 @Medtner3 @76-914 They are 13". Just had to buy some. Be aware there are two versions. The original wiper arms were 7.5mm width. Replacements are 9mm. The attachment piece on the blade has to match the arm. Pelican has both. Local auto parts stores are not likely to have the 7.5mm width. I went through this a while ago. Never found any local ones to buy. Had two counter guys thoroughly confused. |
Literati914 |
Nov 20 2021, 01:02 PM
Senior Member Group: Members Posts: 1,475 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Medtner3 |
Nov 20 2021, 01:21 PM
Any suggestions as to what the correct period wiper blades would be for 1974 914 @Medtner3 @76-914 They are 13". Just had to buy some. Be aware there are two versions. The original wiper arms were 7.5mm width. Replacements are 9mm. The attachment piece on the blade has to match the arm. Pelican has both. Local auto parts stores are not likely to have the 7.5mm width. thanks |
Lo-Fi Version | Time is now: 6th June 2024 - 09:01 AM |
