| Fanmac |
Nov 23 2021, 12:00 PM
Newbie ![]() Group: Members Posts: 5 Joined: 23-November 21 From: SC Member No.: 26,102 Region Association: None |
Hello,
Please listen to the attached video and tell me what you think. It sounds like top end valve train noise, push rod? See links below, I appreciate your time. 914 1974 1.8 stock https://youtu.be/FjfgbFgZY64 Thanks. |
| Shivers |
Nov 23 2021, 12:19 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| Fanmac |
Nov 23 2021, 01:09 PM
It's fixed, please try again.
| Shivers |
Nov 23 2021, 02:21 PM
I'm hearing a lot of noises, but one sounds free, less rhythmic. Like Maybe something bouncing around in the fan, or a piece of something bouncing around in a cylinder.
| Robarabian |
Nov 23 2021, 02:44 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
Something in the fan shroud... blowing around.. I agree. If it was in a cylinder you would know it!
I'm hearing a lot of noises, but one sounds free, less rhythmic. Like Maybe something bouncing around in the fan, or a piece of something bouncing around in a cylinder. |
| Van B |
Nov 23 2021, 05:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
The engine sounds too smooth and steady for it to be valve train for crank related. Plus I too get a tumble dryer impression. I wonder what the fan sucked up?
| wonkipop |
Nov 23 2021, 06:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
The engine sounds too smooth and steady for it to be valve train for crank related. Plus I to get a tumble dryer impression. I wonder what the fan sucked up? mmmm except @Fanmac is homing in over the back of the engine over #3? where he can hear the noise or it seems like the noise is? you have a 1.8 Fanmac? there is the old screwdriver trick. holding it to the engine and putting your ear to it. you need one of those big old mothar screwdrivers. only problem is engine tin kind of gets in the way of listening properly. i dunno - its hard to tell off the video given phone camera sound. but that could be hole in the exhaust headers underneath. a little pinhole? the sound of unburned fuel in exhaust detonating with extra little bit of oxygen? good luck. as others have said, its sounds like its running real sweet and even. so that is a good sign. |
| wonkipop |
Nov 23 2021, 06:35 PM
ah no i see its #4.
still it seems like maybe its back from the fan that you are hearing it. over in the area above #4. still as above suggestion, you are not hearing a noise come up that open heating air riser from the heat exchangers? i notice its got no cap seal on it or blower fan hook up. could channel noise? EDIT another thought for noise in that area. cooling flap has failed in some way? that one in the ducting in oil cooler area has a clip like connection. broken and the flap is rattling in the airstream? watch this video. i think no matter what it will fail in fail safe position for air flow. but it could bounce and rattle around if it looses its fastening. https://www.youtube.com/watch?v=Q2_dzR1qJ6A |
| Van B |
Nov 23 2021, 09:42 PM
That’s a good theory about the cooling flap Wonkipop!
| 914sgofast2 |
Nov 23 2021, 10:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 796 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
The proverbial lost 10mm socket kicking around in the fan shroud housing?
| bretth |
Nov 24 2021, 12:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Mouse carcass flopping around in air ducts?
| 930cabman |
Nov 24 2021, 06:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| Fanmac |
Nov 24 2021, 07:20 AM
Wow!! Thanks for all the replies. I'm hitting it again today and will definitely circle back and let you know the outcome.
| iankarr |
Nov 24 2021, 09:32 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
@wonkinpop. You should be a doctor with those diagnostic skills. Definitely sounds related to a loose body of some sort.
| Fanmac |
Nov 24 2021, 10:00 AM
Ok, removed the tinware and got into the shroud. Found nothing. Also, the noise seems loudest on passenger valve cover and the tinware up top that covers aforementioned cooling flap. we manipulated the cooling flap while it was running and the noise does not change.
Still stumped. |
| rjames |
Nov 24 2021, 11:27 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Maybe remove the valve cover and check for a broken retaining wire or something else bouncing around in there? Longshot, but I can't think of anything else in that area that would be moving around.
| wonkipop |
Nov 24 2021, 02:10 PM
Maybe remove the valve cover and check for a broken retaining wire or something else bouncing around in there? Longshot, but I can't think of anything else in that area that would be moving around. you are thinking a pushrod tube clip? @Fanmac how did the noise start? have you gotten under the car - can you get it up on ramps/hoist safely to take a look/listen from below while its running. |
| Wew |
Nov 24 2021, 02:38 PM
Member ![]() ![]() Group: Members Posts: 236 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
+me on the push rod to rocker spacing. too loose. I had a similar issue on mine but way louder than yours.
Definitely remove the valve covers and check. I am assuming these are mechanical lifters and not hydraulic. Check spacing, could be as simple as that. |
| Fanmac |
Dec 1 2021, 10:45 AM
Well, we checked everything listed above and still no solution. At this point, we're going to take to see a VW specialist. Thanks everyone.
| rfinegan |
Dec 1 2021, 11:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Sounds like an exhaust noise to me...look for leaks at HE, and at the Heads to Cylinders (head gaskets) Stethoscope, smoke machine, or Hose to ear work well...
Well, we checked everything listed above and still no solution. At this point, we're going to take to see a VW specialist. Thanks everyone. |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:07 PM |
