| second wind |
Nov 26 2021, 01:03 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif)
gg |
| ChrisFoley |
Nov 26 2021, 07:04 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif) gg Check with High Performance House in Redwood City. |
| GregAmy |
Nov 26 2021, 08:21 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,700 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I'd be interested in learning more, now that I have the Microsquirt to tune for it.
| Geezer914 |
Nov 26 2021, 09:33 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,358 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon. My engine is a 2056 using 1.8L plenum, runners, and Let fuel injection.
| Shivers |
Nov 26 2021, 09:41 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,600 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
The horn on the air box will flow how much? They look pretty small.
| larryM |
Nov 26 2021, 12:36 PM
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California
did it long ago 0n my D-jet 2.0 euro 4 with webcam73 - made midrange boost you could really feel - iirc it was a 4mm overbore
back then it was being done by Ed Mazula in SoCal - i've archived all my 914 documents; i think you can find an old post by me with the info |
| windforfun |
Nov 26 2021, 12:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,115 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Happy Thanksgiving everyone....so I have seen this before but have never heard about the results.....is the idea any good? How do we get it done on our cars? Just thinking out loud....thank you (IMG:style_emoticons/default/smile.gif) gg Check with High Performance House in Redwood City. Careful. HPH is rather expensive IIRC. |
| BeatNavy |
Nov 26 2021, 04:02 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon I've seen this mentioned in threads before, primarily for the 1.8L plenum. Does anyone know of a good thread demonstrating how to do this on a 2.0? I'd love to open up air flow a bit for my 2270, not just for WOT but for getting more air at cold starts. |
| Maltese Falcon |
Nov 26 2021, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,370 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
RC Fuel Injection in Torrance , California.
They enlarged our 2L t/b, and installed a larger dia butterfly with new shaft o-rings. Fair pricing as well. |
| Geezer914 |
Nov 26 2021, 06:12 PM
I did cut back the air horn and used a 55mm motorcycle velocity stack on eBay for $12.
| Shivers |
Nov 26 2021, 06:27 PM
I did cut back the air horn and used a 55mm motorcycle velocity stack on eBay for $12. Now we're talking (IMG:style_emoticons/default/smile.gif) |
| Montreal914 |
Nov 26 2021, 10:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,198 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon I've seen this mentioned in threads before, primarily for the 1.8L plenum. Does anyone know of a good thread demonstrating how to do this on a 2.0? I'd love to open up air flow a bit for my 2270, not just for WOT but for getting more air at cold starts. @BeatNavy Rob, I tend to find more information on Shoptalkforums on this topic. Here's a thread looking at plenum efficiency and Vanagon TB. Seems appropriate for your 2270. (IMG:style_emoticons/default/smile.gif) But do some search there as there is a lot more information. Pyledriver seems pretty knowledgeable. https://shoptalkforums.com/viewtopic.php?t=102542 Definitely following closely all of your engine work/optimization. (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/smile.gif) |
| GregAmy |
Nov 26 2021, 10:57 PM
I can offer one data point that may be useful...in reviewing the Microsquirt datalogs for my car, when I rev it up at full throttle I rarely see below 96-97kPa...my GM MAP sensor is mounted on the plenum and has a hose going into one of the big hose fittings in the plenum itself. This implies to me that the throttle body is not really that much of a restriction. Stock 1974 2L D-jet plenum, runner, and throttle body, 2056 with mild street cam.
Rob, I'd be interested in what your data logs show for a full throttle, full-RPM run. |
| BeatNavy |
Nov 27 2021, 09:54 AM
Look on the Samba for a 2.1L Vanagon throttle body. They are 50mm vs 45. You have to modify the throttle shaft on your existing throttle body to fit the larger throttle plate in order to keep the TPS. I enlarged the plenum to 50 mm with a tail pipe expander and ordered a new gasket for a Vanagon I've seen this mentioned in threads before, primarily for the 1.8L plenum. Does anyone know of a good thread demonstrating how to do this on a 2.0? I'd love to open up air flow a bit for my 2270, not just for WOT but for getting more air at cold starts. @BeatNavy Rob, I tend to find more information on Shoptalkforums on this topic. Here's a thread looking at plenum efficiency and Vanagon TB. Seems appropriate for your 2270. (IMG:style_emoticons/default/smile.gif) But do some search there as there is a lot more information. Pyledriver seems pretty knowledgeable. https://shoptalkforums.com/viewtopic.php?t=102542 Definitely following closely all of your engine work/optimization. (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/smile.gif) Thanks Montreal914 ! That's a very interesting thread, although wow do they go into 8 pages of theoretical. What my smallish brain took from Jake and everyone else's postings: plenum turbulence is bad and at some point smoother air is at least as important if not more than simply MORE air. Not sure what to do with that, tho? Try a bus plenum? FYI, I did reach out to RC Fuel Injection about cost / recommendation for boring out a 2.0 TB. Looks like the base cost for "most Porsches" is $289. Not sure what that includes, but I'll pass info along. Given that it was late Friday afternoon, I don't expect a response for a few days. Thanks for the tip, Maltese Falcon . I can offer one data point that may be useful...in reviewing the Microsquirt datalogs for my car, when I rev it up at full throttle I rarely see below 96-97kPa...my GM MAP sensor is mounted on the plenum and has a hose going into one of the big hose fittings in the plenum itself. This implies to me that the throttle body is not really that much of a restriction. Stock 1974 2L D-jet plenum, runner, and throttle body, 2056 with mild street cam. Rob, I'd be interested in what your data logs show for a full throttle, full-RPM run. Greg, good idea. I follow your logic. I don't know enough to know if it's valid or not, but I do get the logic, and I'll try to post something soon. I actually haven't done a real run since I put the BMW IAC on it last week and played with the tune, but at WOT nothing should have changed. With Thanksgiving house guests and the colder temps (and heat not currently hooked up on my car) I haven't had a chance to really run it. EDIT: User tagging not working up in the body of my response for some reason (IMG:style_emoticons/default/confused24.gif) @Montreal914 @Maltese Falcon |
| Montreal914 |
Nov 27 2021, 10:48 AM
At this price point on the TB modification, I would seriously consider this one from GoWesty. I definitely like the sealed ball bearing for the throttle shaft. There might be a TPS/lever orientation issue ( I have read somewhere) but someone had gone around this problem. I think I had read it on STF. Obviously, this would mount on a Vanagon plenum which might be better for the 2270(?) (IMG:style_emoticons/default/confused24.gif)
https://www.gowesty.com/product/electrical/...e-valve-housing ![]() |
| GregAmy |
Nov 27 2021, 12:12 PM
$300 for a new TB ain't hateful. But you'd need to see if the TPS is swappable, as this is a single-mciroswitch Digifant setup.
They offer a "Gowesty Fuel Injection Component Replacement Kit" that uses a "All-new Billet Aluminum Throttle Body with modern TPS" so I'm guessing it could be converted...? https://www.gowesty.com/product/electrical/...ement-system?v= |
| BeatNavy |
Nov 27 2021, 12:35 PM
I believe @JamesM is running the Vanagon TB and plenum. I'd be interested in what's required to make that work. I can't find a good pic of one of those plenums, as I'd like to see what the vacuum outlet/port selection is like.
I think this is is rig. Very clean setup. But I can already see I'd probably have wiring harness issues with the way it's oriented. (IMG:http://www.914world.com/bbs2/uploads/post-5834-1576449659_thumb.jpg) |
| JamesM |
Nov 27 2021, 11:11 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,307 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I believe @JamesM is running the Vanagon TB and plenum. I'd be interested in what's required to make that work. I can't find a good pic of one of those plenums, as I'd like to see what the vacuum outlet/port selection is like. I think this is is rig. Very clean setup. But I can already see I'd probably have wiring harness issues with the way it's oriented. (IMG:http://www.914world.com/bbs2/uploads/post-5834-1576449659_thumb.jpg) Throttle body is 2.1 vanagon, the plenum and runners though are 74 1.8 parts. Only modification made was using a tailpipe expander to open up the plenum to match the 50mm vanagon TB, and swapping the throttle arm from a 1.8 throttle body over to the vanagon throttle body for proper throttle cable orientation. Using the Vanagon plenum is a bit more complicated as no 914 intake runners are a direct match to it. |
| JamesM |
Nov 27 2021, 11:18 PM
At this price point on the TB modification, I would seriously consider this one from GoWesty. I definitely like the sealed ball bearing for the throttle shaft. There might be a TPS/lever orientation issue ( I have read somewhere) but someone had gone around this problem. I think I had read it on STF. Obviously, this would mount on a Vanagon plenum which might be better for the 2270(?) (IMG:style_emoticons/default/confused24.gif) https://www.gowesty.com/product/electrical/...e-valve-housing ![]() I have one of these on the bench waiting to be installed this winter as my motor is needing even more air than the 50mm vanagon TB can provide. The throttle arm is in the wrong orientation and needs to be swapped and due to the design of the TB itself it is not as straight forward a swap as using a stock 2.1 vanagon TB. The GoWesty unit however is 52mm and uses a flat throttle plate as opposed to the 2.1 vanagons tapered thottle plate that creates some restriction at WOT. Its a really nice piece, out of the box its actuation is buttery smooth. |
| Porschef |
Nov 28 2021, 09:46 AM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
I think Mr Kona had a thread on this, well done.
Chris, I have the enlarged throttle body on my car that you did years ago, it definitely made a difference on the 2056 (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 22nd September 2026 - 04:41 PM |
