Replacing the rear seal |
Geezer914 |
Dec 13 2021, 12:00 PM
Geezer914 Group: Members Posts: 1,749 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I have to replace the rear seal. Should I pull the transfer case or drop the whole engine?
mate914 |
Dec 13 2021, 12:03 PM
Matt Group: Members Posts: 793 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
just the transmission.
Matt (IMG:style_emoticons/default/flag.gif) |
DRPHIL914 |
Dec 13 2021, 12:44 PM
Dr. Phil Group: Members Posts: 5,809 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have to replace the rear seal. Should I pull the transfer case or drop the whole engine? I agree with Matt, just the transmission if you are just doing the rear main seal. that way you dont have to disconnect the fuel likes and all the electric. I will be doing the same due to RMS leak as well. Phil |
iankarr |
Dec 13 2021, 02:17 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,519 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Agreed. If it's just the rear main, no need to drop the engine. BUT. If there's anything else you need to do (valves, inspection, pushrod tube seals, etc. I'd drop it.
Aerostatwv |
Dec 13 2021, 07:08 PM
Member Group: Members Posts: 123 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Don’t forget the o-ring in the flywheel..
IronHillRestorations |
Dec 13 2021, 07:31 PM
I. I. R. C. Group: Members Posts: 6,768 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Get a Sabo RMS from gowesty.com, it’s the only one to use
Lo-Fi Version | Time is now: 31st October 2024 - 06:08 PM |
