mmascari |
Member ![]() ![]() Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None ![]() |
I need to replace the small hose from the gas filler to the expansion tank used for venting. I tried to find the size of the hose and couldn't find it. It is the smaller hose. Hope someone can tell me. Also, I found cloth braided vacuum hose from JBugs site. Any other sources?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I need to replace the small hose from the gas filler to the expansion tank used for venting. I tried to find the size of the hose and couldn't find it. It is the smaller hose. Hope someone can tell me. Also, I found cloth braided vacuum hose from JBugs site. Any other sources? This is what you need. https://www.pelicanparts.com/More_Info/2110...9&DID=49311 |
mmascari |
I need to replace the small hose from the gas filler to the expansion tank used for venting. I tried to find the size of the hose and couldn't find it. It is the smaller hose. Hope someone can tell me. Also, I found cloth braided vacuum hose from JBugs site. Any other sources? This is what you need. https://www.pelicanparts.com/More_Info/2110...9&DID=49311 Thank you! That is exactly what i was looking for |
Lo-Fi Version | Time is now: 10th June 2024 - 10:57 PM |
