| worn |
Jan 14 2022, 07:45 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,648 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Hi Folks,
The welding of my 2056 car is drawing to a close and I think of priming and painting. Normally I use a PPG epoxy like DP40. Right now I have some epoxy primer from Eastwood on hand. I plan to paint the car in the original silver, so I hope to use PPG DBC base coat under a PPG clear. Can I use the Eastwood product (that looks sort of like Kirker) underneath. The money is not my issue: it is trying not to be wasteful. Thanks. Stay safe and happy. |
| mepstein |
Jan 14 2022, 07:48 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,913 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I was always told to stick to the same brand.
| worn |
Jan 14 2022, 08:29 PM
| mepstein |
Jan 14 2022, 09:23 PM
I was always told to stick to the same brand. Makes sense except I have a gallon with no other place to go. I should add that PPG makes great stuff. Thus the comment at the sales desk: “you know how much DCC costs?” I would check with the paint rep from whatever companies product you plan the use over the Eastwood epoxy. |
| IronHillRestorations |
Jan 14 2022, 09:50 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,955 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Use the Eastwood on the secondary surfaces, trunks, engine bay, etc. It's not going to make a difference in those areas IMHO
| Can-Am |
Jan 14 2022, 10:32 PM
Newbie ![]() Group: Members Posts: 37 Joined: 20-November 07 From: Scottsdale, AZ Member No.: 8,360 Region Association: None
Spray the Eastwood epoxy to seal the bare metal. Let it cure for a couple of days, scuff sand it and spray some PPG filler primer over the top of it. I don't think that's a problem. If you're nervous do the 2" tape test. Stick the tape down with pressure and then pull it off fast as if it's going to hurt.
Once they took the lead out of DP epoxy it hasn't been my favorite. Tastes great and less filling. |
Lo-Fi Version | Time is now: 18th September 2026 - 04:46 AM |
