Boxster brake upgrade |
dwillouby |
Jan 20 2022, 04:26 PM
Member Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Been wondering if it would be worth the time and money to upgrade to Boxster front and rear brakes?
Currently have a 5 lug setup with 911S calipers on the front and I believe M calipers on the rear. 19mm m/c. Believe the rotors are 911 Carrera. The brakes work very well so dont know if I would see a noticeable difference in braking to be worth it. The car is an LS conversion for street use only. Thanks David |
dwillouby |
Jan 20 2022, 04:28 PM
Been wondering if it would be worth the time and money to upgrade to Boxster front and rear brakes? Currently have a 5 lug setup with 911S calipers on the front and I believe M calipers on the rear. 19mm m/c. Believe the rotors are 911 Carrera. The brakes work very well so dont know if I would see a noticeable difference in braking to be worth it. The car is an LS conversion for street use only. Thanks David Sorry this should be in the garage. |
Lo-Fi Version | Time is now: 12th June 2024 - 04:31 AM |
