> What is best tool to get oil filter out
rosenfe
post Jan 25 2022, 11:26 AM
I’ve tried various cup like tools, but they are either to big or small. Ian karr has one in his video that looked good. Not sure where he got it. What do you guys use?
Replies(1 - 11)
yeahmag
post Jan 25 2022, 11:40 AM
I like this style:
https://www.amazon.com/TEKTON-5866-12-Inch-...sr=8-6&th=1
I have the 3 jaw ones too that I use sometimes. Something like this:
https://www.amazon.com/Milliontronic-Oil-Fi...132&sr=8-28
jrmdir
post Jan 25 2022, 11:42 AM
The TEKTON pliers worked well for me also.
Ron
JeffBowlsby
post Jan 25 2022, 12:07 PM
914 Wiring Harnesses
Large channel locks
brubou
post Jan 25 2022, 12:13 PM
Bruce Bouchard
I find this easiest.
https://www.harborfreight.com/universal-3-j...pBoCaeEQAvD_BwE
Mark Henry
post Jan 25 2022, 12:26 PM
that's what I do!
QUOTE(JeffBowlsby @ Jan 25 2022, 01:07 PM) *
Large channel locks
iankarr
post Jan 25 2022, 12:33 PM
Links to the tools shown in the video are in the Youtube description pane. You may need to open it up. I get no benefit from purchases (IMG:style_emoticons/default/wink.gif).
Shivers
post Jan 25 2022, 01:28 PM
When all else fails, I put the oil pan under it and hammer a screw driver through it. Turn clockwise
Dredwin
post Jan 25 2022, 01:51 PM
QUOTE(Shivers @ Jan 25 2022, 12:28 PM) *
You have to be careful doing it this way...the first time I tried to remove the filter with various wrenches failed and I tried this...only to fail and have a car with no oil and a stuck filter. I ended up getting one of those removal tools that has a chain and it compressed the busted filter quite a bit. I had to wrap it around as close to where it attached to the engine and cursed up a storm to get it off. Ironically, my daughter did the same thing when she overtightened her filter and she used a screwdriver without talking to me first). In my defense, the prior owner also was unable to remove the filter so it wasn't me that tightened it.
Geezer914
post Jan 25 2022, 05:19 PM
Geezer914
Use K&N filters with a 1" nut welded to the bottom.
post Jan 25 2022, 06:55 PM
This won't help you remove it; this time. Do this and you will never fight one again. Buy a small tube of 100% silicone grease. Found in most hardware and plumbing supply houses. Smear the gasket with a thin layer then screw the filter back on. That's it! An old A&P taught me that several years back. You haven't lived until you try to remove an oil filter from the rear of a Lycoming engine. (IMG:style_emoticons/default/wacko.gif)
bkrantz
post Jan 25 2022, 08:15 PM
Over the years I have used all kinds, but seem to use the strap type the most. I can almost always find a position for access and clearance to swing the handle enough to start the filter turning.
https://www.amazon.com/ARES-56046-Wrenches-...708821&th=1
- Lo-Fi Version Time is now: 16th June 2024 - 07:50 PM
