bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,466 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
After filling my brake system with all new components and stainless hard lines, I found several leaking connections. When I installed all the lines I made up the connections as tight as I normally would. Do the stainless lines, and flared ends, need more torque to seat and seal?
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,993 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
yes, ss is harder than the stock lines and doesn't crush to shape as easily. Eric Shea might have some comments or tricks to help you.
bkrantz |
According to some online sources, a good way to get the stainless lines to seat properly is to cycle tight-loose 5 or 6 times, and then tighten. That is supposed to assist seating by progressive deformation of the flare.
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,311 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
I got some stainless lines from PMB and had the same problem. Finally sent them back and got the regular steel. They told me the same thing (afterwards...); you have to really tighten down hard to seat the flare.
I also found the SS lines were much harder to make minor bend adjustments when installing. In the end, staying with the factory steel was just easier. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,765 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
This is why I like the nicklecopper brake lines. It bends easy, and it really takes that flare and seals up great.
Zach |
Lo-Fi Version | Time is now: 31st July 2025 - 10:00 AM |
