WTB Console Parts, Hardware Needed |
NARP74 |
Feb 1 2022, 01:43 PM
Senior Member Group: Members Posts: 1,075 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I picked up a decent center console but it had no hardware. I have looked around and asked my local sources, came up empty. Anyone have this lying around and want to let it go? Let me know.
U bracket for console to car body, X1 Screws and washers for the U bracket to body, X2 Screws and washers for the U bracket to the console, X2 Spring clips for the upper gauge pad to the console, have the bracket, X2 Bracket for the lower pad to the console in front, have the clip, X1 Screws for the bracket to the front of the console, X2 Plastic trim filler for the heat lever slot, X1 Screw and washer for the bracket to the car floor mount, X1 Thanks |
BillJ |
Feb 1 2022, 02:03 PM
Senior Member Group: Members Posts: 1,116 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Automobile Atlanta just made all that stuff new.
NARP74 |
Feb 1 2022, 02:08 PM
Well I looked there and could not find any, of course. Then I sent them an email a while ago and got no response. Not sure how to give them my money...
BillJ |
Feb 1 2022, 02:18 PM
Phone call always works for me
NARP74 |
Feb 1 2022, 02:32 PM
I'll try that. Anyone else?
FlacaProductions |
Feb 1 2022, 04:35 PM
Senior Member Group: Members Posts: 1,629 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
NARP74 |
Feb 1 2022, 05:06 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something.
rgalla9146 |
Feb 1 2022, 08:30 PM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. |
NARP74 |
Feb 2 2022, 11:14 AM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. Let me know |
NARP74 |
Feb 3 2022, 12:31 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. Any update? @rgalla9146 |
rgalla9146 |
Feb 3 2022, 02:10 PM
Thanks, I only need 2 of those brackets and all of the hardware which isn't mentioned in the ad. I will try to get in touch with them and see if they can do something. You still need the U bracket ? I have one ( flat U bracket ) on the shelf but must check that it is not from one of my cars. I'll check tomorrow. Any update? @rgalla9146 I'm sorry for the delay I cannot get to one of the cars ( I have two early ) so have to say I can't help you out. |
NARP74 |
Feb 3 2022, 02:33 PM
OK, thanks anyway
NARP74 |
Feb 4 2022, 11:07 AM
Still looking
burton73 |
Feb 4 2022, 12:13 PM
burton73 Group: Members Posts: 3,559 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
burton73 |
Feb 4 2022, 12:14 PM
PanelBilly |
Feb 5 2022, 04:24 PM
914 Guru Group: Members Posts: 5,821 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
You don’t need that u. Racket. The thing fits tight between the floor and the dash. Haven’t had one for years. Nothing moves.
NARP74 |
Feb 8 2022, 10:51 AM
I'll try a test fit, thanks. Still need some other bits.
Lo-Fi Version | Time is now: 17th June 2024 - 11:50 AM |
