| yeahmag |
Feb 3 2022, 06:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,485 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Where are people sourcing exhaust gaskets for the Tangerine headers? Damned if I can find a gasket with the right bolt spacing...
Collector 2.25" OD with 3.5" (ish) bolt spacing, 2 bolt Stub pipes 1.75" ID with 2.4" (ish) bolt spacing, 2 bolt |
| bdstone914 |
Feb 3 2022, 07:42 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,393 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Where are people sourcing exhaust gaskets for the Tangerine headers? Damned if I can find a gasket with the right bolt spacing... Collector 2.25" OD with 3.5" (ish) bolt spacing, 2 bolt Stub pipes 1.75" ID with 2.4" (ish) bolt spacing, 2 bolt Maybe ask Chris Foley ? |
| rfinegan |
Feb 4 2022, 06:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,227 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
| ChrisFoley |
Feb 4 2022, 06:25 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,032 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
The stepped flange stub pipe connections are not intended to have gaskets.
A standard gasket for the tailpipe/muffler flanges should be available at your FLAPS. I can supply a part # when I'm at work. |
| yeahmag |
Feb 4 2022, 10:52 AM
Thanks Chris! Got your email with the part number. Really appreciate that and the tips for a hanger. Your suggestion is similar to what I've built on my current exhaust. Time to get the welder out...
| carreras0 |
Sep 29 2026, 10:53 PM
Newbie ![]() Group: Members Posts: 3 Joined: 11-September 09 From: CA Member No.: 10,795 Region Association: None |
The stepped flange stub pipe connections are not intended to have gaskets. A standard gasket for the tailpipe/muffler flanges should be available at your FLAPS. I can supply a part # when I'm at work. Hey Chris, Can you repost the gasket information here for your EVO headers. I need 4 x 1.75 in and 2 x 2.25 gaskets Thank you, Chris |
Lo-Fi Version | Time is now: 30th September 2026 - 12:37 AM |
