WTB: Pedal cluster parts |
DLewis |
Mar 10 2022, 02:41 PM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
I need a clutch shaft tube.
It bolts to the side of the base and the clutch shaft goes through it. And a silver nut the is on the brake rod. It kind of has a shoulder on it. Don't know what it does but the one I had was half gone. Dean |
Montreal914 |
Mar 10 2022, 02:55 PM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
bdstone914 |
Mar 10 2022, 04:08 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I need a clutch shaft tube. It bolts to the side of the base and the clutch shaft goes through it. And a silver nut the is on the brake rod. It kind of has a shoulder on it. Don't know what it does but the one I had was half gone. Dean I cant spare any clutch tubes as many are badly rusted. Uro is making a replacement. I use a 10mm stainless jam nut for the brake rod. I tap a tapered punch into the hole to fkatten the threads a little and press it on. |
DLewis |
Mar 11 2022, 10:28 AM
I need a clutch shaft tube. It bolts to the side of the base and the clutch shaft goes through it. And a silver nut the is on the brake rod. It kind of has a shoulder on it. Don't know what it does but the one I had was half gone. Dean I cant spare any clutch tubes as many are badly rusted. Uro is making a replacement. I use a 10mm stainless jam nut for the brake rod. I tap a tapered punch into the hole to fkatten the threads a little and press it on. thanks Buce. I will have to keep looking Dean |
DLewis |
Mar 22 2022, 10:38 AM
still looking
KevinW |
Mar 22 2022, 11:08 AM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
Dean,
I still have the clutch tube that I sent you pictures of. Kevin |
DLewis |
Mar 23 2022, 09:51 AM
Kevin
sent you a PM and replied to your email last week? Dean |
Lo-Fi Version | Time is now: 31st May 2024 - 07:31 PM |
