1974 LE Bumblebee Script color |
914bee |
Mar 27 2022, 05:03 PM
Newbie Group: Members Posts: 6 Joined: 15-March 14 From: St. paul, mn Member No.: 17,120 Region Association: Upper MidWest |
I have an original paint LE Bumblebee. The yellow body parts needed to be redone and I used the paint code to match. It appears the P script on the sides are the same yellow but I can not source this color of script. I have purchased the scripts from 914 suppliers but they do not match. Is this the case? Suggestions - and I have gone to many local companies whom create original scripts with no luck. This car is a time piece. Thanks for suggestions!
JeffBowlsby |
Mar 27 2022, 06:30 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have an original paint LE Bumblebee. The yellow body parts needed to be redone and I used the paint code to match. It appears the P script on the sides are the same yellow but I can not source this color of script. I have purchased the scripts from 914 suppliers but they do not match. Is this the case? Suggestions - and I have gone to many local companies whom create original scripts with no luck. This car is a time piece. Thanks for suggestions! Last I checked, the availbale yellow vinyl colors are close to the factory sunflower yellow, but not exact. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:14 AM |
