Alternator, Voltage Regulator, or Something Else? |
yeahmag |
May 4 2022, 11:22 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm having an intermittent problem where over 3500 RPM (cruise speed for example) the alternator light will come on. If you LOWER the RPM the light goes out and has never come on at idle even with a full electrical load. I've done the following to try and figure it out:
yeahmag |
May 4 2022, 11:36 PM
The only other thing I can come up with is the brushes are getting week and the centrifugal force imposed on them is pushing them away, not letting them do their job. Just spitballing here...
GregAmy |
May 5 2022, 05:19 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
yeahmag |
May 5 2022, 05:34 PM
I just did the test on the D+ side of the light (blue wire) and it goes to 5V. It doesn’t go high…
Spoke |
May 7 2022, 06:07 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I just did the test on the D+ side of the light (blue wire) and it goes to 5V. It doesn’t go high… When does it go to 5V? It should be at battery voltage so there is no current through the GEN light. Did you check the voltages of the VR and battery? D- to chassis D+ to chassis DF to chassis Battery voltage to chassis Do these tests with headlights on at idle and 3500RPM. If D+ is equal to the battery voltage at low RPM then drops with high RPM, it might indicate some sort of rotational issue. Not on a 914 but I had a car where the alternator would charge at idle then virtually stop working at higher RPMs. Removed the alternator and checked the resistance across the brushes and armature. Got a resistance value then when I spun the rotor, the resistance went way up. Took the alternator apart and cleaned the brushes and commutation ring and the alternator worked perfectly after that. |
PatMc |
May 7 2022, 08:55 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
tighten the belt a bit and see if it changes
yeahmag |
May 7 2022, 10:08 PM
Had an autocross this morning and the alternator completely failed on my way to the event. Turned around and made it home under battery alone with no problem. Bruce is getting me a rebuilt unit this week.
bdstone914 |
May 7 2022, 11:11 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Lo-Fi Version | Time is now: 8th June 2024 - 06:29 PM |
