FS 911 Boge Struts 3.5" Caliper Bolt Spacing $600 |
bdstone914 |
May 11 2022, 12:23 PM
bdstone914 Group: Members Posts: 4,542 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This is a pair of late 911 Boge struts with the 3.5" caliper bolt spacing that allows use of bigger brakes.
They have been powder coated and include top retainer caps, spacers on the spindles, keyed washers and spindle lock nuts. These are the later 911 style made after 3/85 and have external threads at the top for the retainer cap. They accept either Boge or Bilstein inserts. Only one top cap and spacer are shown but the other parts are on order and expected this week. Price is $600 shipped in the U.S. Attached thumbnail(s) |
mepstein |
May 11 2022, 02:15 PM
914-6 GT in waiting Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Really nice looking set. Hardware isn’t cheap.
grantjd |
May 12 2022, 06:55 AM
Newbie Group: Members Posts: 9 Joined: 29-January 09 From: CO Member No.: 9,997 Region Association: Rocky Mountains |
Koni’s wont fit these?
Steve |
May 12 2022, 07:44 AM
914 Guru Group: Members Posts: 5,619 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
fctry |
May 12 2022, 08:43 AM
I'm new here ... Group: Members Posts: 0 Joined: 17-March 22 From: Virginia Member No.: 26,405 Region Association: South East States |
Edit, asked
fctry |
May 12 2022, 08:47 AM
PM sent
bdstone914 |
May 12 2022, 01:30 PM
Koni’s wont fit these? Both Koni and Bilstein make special inserts for boge struts. @steve @grantjd Koni lists the 8641 insert to fit all 911 and 914 but that is not correct. I tried one in this late strut and the insert does not locate in the bottom and the top not does not center the insert as the late top caps do not go inside the tube over the insert. The insert has about a half inch of vertical movement. Bruce |
Steve |
May 12 2022, 02:13 PM
Koni’s wont fit these? Both Koni and Bilstein make special inserts for boge struts. @steve @grantjd Koni lists the 8641 insert to fit all 911 and 914 but that is not correct. I tried one in this late strut and the insert does not locate in the bottom and the top not does not center the insert as the late top caps do not go inside the tube over the insert. The insert has about a half inch of vertical movement. Bruce Thanks Bruce. I have early 911S Boge struts with the inside cap. Good to know!! |
bdstone914 |
May 14 2022, 03:32 PM
914werke |
May 14 2022, 04:46 PM
"I got blisters on me fingers" Group: Members Posts: 10,157 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Both spacer rings? Nvr mind I should learn to read.
Lo-Fi Version | Time is now: 17th June 2024 - 01:15 AM |
