> Targa pad removal…, Big thanks to 914Toy aka Keith Hully ! It’s done….
jim_hoyland
post May 16 2022, 02:12 PM
Get that VIN ?
Got a pair of new latches for the targa top. Seven horizontal screws and 5 vertical from underneath. Screw heads are buried into the pad. Any tricks here ?I found maybe three of the screws.
Replies(1 - 19)
Root_Werks
post May 16 2022, 02:34 PM
Village Idiot
On the pad I removed (and tossed), the foam inside the little holes had been shredded up enough to block the screw heads. I used a little pick to sort of clean out each hole. The screw heads don't always match straight to the hole in the pad either. It's frustrating and slow. You should be able to see each screw head....should.
jim_hoyland
post May 16 2022, 03:06 PM
Get that VIN ?
QUOTE(Root_Werks @ May 16 2022, 01:34 PM) *
Good suggestion ! Do the panel covering the rear pillars have to come off ?
I can see one screw hear may have a mated head, that is the screwdriver can bite in…
Root_Werks
post May 16 2022, 03:50 PM
Village Idiot
I would take the two side panels off, makes things easier.
Should be one small philips screw at the "coat" hangar and the seatbelt bolt.
I installed a new 914 Rubber rear pad and it was so nice not having foam clogging up the holes.
jim_hoyland
post May 16 2022, 03:53 PM
Get that VIN ?
QUOTE(Root_Werks @ May 16 2022, 02:50 PM) *
I’m inclined to replace it; just gotta dye it tan
windforfun
post May 16 2022, 06:57 PM
The AA roll bar pad fits almost perfectly. And how are you going to dye a black vinyl (rubber) pad tan?
Front yard mechanic
post May 16 2022, 07:13 PM
Use a long number one screwdriver . The length helps center it in the hole in the pad
post May 16 2022, 07:17 PM
Jim, the correct size Phillips is #1 on the list. 2nd, use an ice pick or sharp awl to locate the center of the screw. Often they are not installed straight or do not line up with the center of the hole in the pad. OEM, George's or Mark's. Take your time feeling around. after a couple you will get the hang. Those screws that are vertical are a PITA when the rear glass is in. Not enough room between the handle and glass for your fingers around the handle of the screwdriver when the glass is installed so you may need to grip the handle with a pair of pliers on final tightening or when breaking them loose. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland
post May 16 2022, 07:39 PM
Get that VIN ?
QUOTE(windforfun @ May 16 2022, 05:57 PM) *
We have a local upholstery man who paints the tan over the black.
jim_hoyland
post May 16 2022, 07:41 PM
Get that VIN ?
Got the #1 long shaft screwdriver. Had to stop after getting only two screws
windforfun
post May 16 2022, 07:53 PM
QUOTE(jim_hoyland @ May 16 2022, 06:41 PM) *
I think you need to get a wee bit more aggressive there my friend. Pull on the old fucker & yank him out. Be careful not to damage the side pads.
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif)
windforfun
post May 17 2022, 04:11 PM
BTW, some of the screws may already be missing. My "stock" roll bar pad was missing one screw that I obviously, or not so obviously, could't remove.
jim_hoyland
post May 17 2022, 06:00 PM
Get that VIN ?
This project is on hold for awhile. Will restart when I have more time and get some help.
JamesM
post May 18 2022, 01:23 PM
QUOTE(Root_Werks @ May 16 2022, 12:34 PM) *
Thats the kicker, just finding the damn heads of the screws.
One of the pads i removed someone had put a 2nd screw in the hole over the first. so I pulled the screw out of the hole thinking i was good to go, not knowing there was another one hiding back there somewhere still holding the pad on. (IMG:style_emoticons/default/headbang.gif)
bob164
post May 18 2022, 06:33 PM
Jim,
When you get back to it, give me a call and I will come over to help.
Bob
jim_hoyland
post May 18 2022, 06:51 PM
Get that VIN ?
QUOTE(bob164 @ May 18 2022, 05:33 PM) *
Jim,
Bob
Thanks Bob. Will do
Dave_Darling
post May 18 2022, 11:16 PM
914 Idiot
I think I recall that the two little tiny screws in the latch area also held the d**n pad on as well.
--DD
post May 19 2022, 08:38 AM
914-6 GT in waiting
I hate those tiny screws. Made worse after 50 years.
windforfun
post May 19 2022, 10:12 AM
QUOTE(Dave_Darling @ May 18 2022, 10:16 PM) *
--DD
The latch covers only mount to the pad & these screws may be omitted IMO if the latch covers press fit nice & tight. Such is the case with the AA pad.
jim_hoyland
post Aug 16 2022, 04:18 PM
Get that VIN ?
Restarting the targa pad removal. Gonna pull the pillar covers, try the #1 Phillips, and it that fails I’ll try drilling the screw heads off ?
Any suggestions on drill bits ?
- Lo-Fi Version Time is now: 15th September 2026 - 09:28 AM
