| r_towle |
May 17 2022, 05:58 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I wish things were sold as Kits, just saying.
For a leaky oil temp sensor I’m getting Oil temp seal (rubber) Oil temp gasket Two bolt crush washers Is that it or is there some crush washer where the sensor penetrates to metal holder? Rich |
| mgphoto |
May 17 2022, 06:41 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,404 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I think the gasket is only necessary for the cover without the sensor.
I believe there is an aluminum sealing ring for the sensor. |
| 914werke |
May 17 2022, 07:46 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,573 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Its unlikely you'll need the large (orange) O ring. There is a copper crush washer that will go under your sender to plate,
& for the cover, aside from the paper gasket there is a rubber stopper for the wire. Take it out & run a flat file over the bolt holes I bet you'll be taking off metal. Do your best to make sure the thing is flat, then Clean Clean Clean it. I dont put any sealant on the O ring but I will on the shorty M6 bolts. If your efforts were successful ...no leaks. |
| r_towle |
May 17 2022, 08:05 PM
Could not find just the crush washer, but I ordered a new sensor so hopefully the washer is on there.
This needs to be a simple kit…geez |
| 930cabman |
May 18 2022, 01:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,516 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I wish things were sold as Kits, just saying. For a leaky oil temp sensor I’m getting Oil temp seal (rubber) Oil temp gasket Two bolt crush washers Is that it or is there some crush washer where the sensor penetrates to metal holder? Rich That is it, but change all of the above to make sure it's sealed |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:04 AM |
