| mgphoto |
May 17 2022, 07:48 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I am trying to repair a leak in the oil gallery under cylinders 3-4 As you can nearly see, the air deflection plate is up against the leaking clean out plug. I would like to know from someone who has done this before, can I remove the rocker arms and pull the push rods and tubes as far as they will go, can I move the deflector enough to get access to the plug? Thanks for your help. Mike |
| r_towle |
May 17 2022, 08:08 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
You can pull the push rod tube out, you can’t get that piece of tin off without damage
| mgphoto |
May 18 2022, 01:19 PM
So pull the engine?
| r_towle |
May 18 2022, 09:34 PM
I would pull it, mount on engine stand, flip it over and go from there.
You might need to pull the head and cylinders to get where you need to with the proper tools. |
| mgphoto |
May 21 2022, 01:22 PM
| Dave_Darling |
May 22 2022, 12:02 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Pull the pushrod tubes halfway out, then swing the inboard end down and pull them that way. Some won't slide straight out due to the suspension console being in the way, but they can all slide partway out.
--DD |
Lo-Fi Version | Time is now: 30th April 2026 - 09:21 PM |
