Friday, 22 August 2025
> Do I have the rear engine seal upside-down?
bkrantz
post May 24 2022, 08:28 PM
I noticed (and then forgot) this when I first installed the engine, but the rear seal across the vertical sheet metal does not lie close to sealing along the sides. Did I install the rubber upside-down? The shorter flap is on top.
Replies(1 - 2)
914werke
post May 24 2022, 09:48 PM
Looks correct but you need to coax the back flap to the Trans side of the R. tin
mgphoto
post May 25 2022, 08:49 AM
"If there is a mistake it will find me"
The engine tin fits between the two flaps, one flap in the engine compartment and one in the transmission section.
- Lo-Fi Version Time is now: 21st August 2025 - 09:11 PM
