| dflesburg |
Aug 4 2005, 08:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
does the stock speedo work on the 915 with the wevo kit?
| Series9 |
Aug 4 2005, 08:46 AM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
No. I replaced my speedo with oil gauges years ago, so it was no big deal on my car. Having a speedo with a converted 915 is a complicated issue, so I'll let someone who's done it explain the details.
| ArtechnikA |
Aug 4 2005, 08:55 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
915 got electric speedo in 1976.
so - '72-'75 mechanical speedo will work as long as you have a 7:31 915 (most early ones). unfortunately, the earliest 915's are the least desirable. |
| Wild 6 |
Aug 4 2005, 09:53 AM
See you at the next autocross. ![]() ![]() Group: Members Posts: 212 Joined: 16-November 04 From: Phoenix, AZ Member No.: 3,128 |
I have a newer 915 gearbox with an electronic pickup and an electronic speedometer. It works great.
Andy |
| Type 4 Unleashed |
Aug 4 2005, 10:59 AM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Andy, question, howed you hook up your electronic speedo, did you have your ring fliped, and then had the opposite side of the case machined for the electronic speedo pickup, or did you flip your tranny. |
| ClayPerrine |
Aug 4 2005, 11:13 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
| Wild 6 |
Aug 4 2005, 02:07 PM
I read Clay's thread and mine was done the same way - the pickup was moved to the other side of the transmission.
Andy |
Lo-Fi Version | Time is now: 15th March 2026 - 10:57 PM |
