Hard shifting 2nd and 4th |
TonyA |
Jun 28 2022, 05:51 AM
Nachmal Group: Members Posts: 473 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Getting some difficulty going into second and fourth gear. All bushings checked except the rear knuckle pocket one. Trans was low on oil 8-12 oz. Are my sinks toast ?
StarBear |
Jun 28 2022, 06:40 AM
Senior Member Group: Members Posts: 1,908 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Ouch. Hopefully not the Creamsicle and won’t prevent you from bringing it to the NEG. (IMG:style_emoticons/default/beer.gif)
TonyA |
Jun 28 2022, 06:49 AM
Will be there one way or another. Got two spare transmissions but not sure of their condition. One given to me and one from a parts car. Might attempt to swap out without removing the engine unless anyone has a better idea.
Olympic 914 |
Jun 28 2022, 09:26 AM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Hate to state the obvious, but have you checked the adjustment at the shifter?
I have had it move, and it would pop out of gear. Paint some white-out on it. And mark it with a sharpie. That makes it easier to see how much you move it AND if it moves again in the future. |
rjames |
Jun 28 2022, 09:31 AM
I'm made of metal Group: Members Posts: 3,954 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Will be there one way or another. Got two spare transmissions but not sure of their condition. One given to me and one from a parts car. Might attempt to swap out without removing the engine unless anyone has a better idea. No need to remove the engine if just swapping out the transmission. Good luck! |
Spoke |
Jun 28 2022, 10:03 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I just went through a hard time getting into 2nd. Turns out it was the cone screw had come loose. Tightened it and 2nd is not an issue now.
rhodyguy |
Jun 28 2022, 12:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
2nd and 4th are in the same plane. Does the free play seem the same in 2nd and 3rd? It doesn't need to be running.
ndfrigi |
Jun 28 2022, 12:37 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi Tony! have you tried shifting the gear at the rear by the transmission?
TonyA |
Jun 28 2022, 03:02 PM
TonyA |
Jun 28 2022, 03:04 PM
Hate to state the obvious, but have you checked the adjustment at the shifter? I have had it move, and it would pop out of gear. Paint some white-out on it. And mark it with a sharpie. That makes it easier to see how much you move it AND if it moves again in the future. Thanks I should have it apart tonight I hope. |
emerygt350 |
Jun 28 2022, 07:09 PM
Advanced Member Group: Members Posts: 2,137 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Did you check the cone screw?
TonyA |
Jun 28 2022, 10:39 PM
Yep it was a loose cone screw. I installed two new ones and a new shifter bushing at the side shifter knuckle. Thanks I should have suspected the obvious first
emerygt350 |
Jun 30 2022, 06:07 AM
Great to hear it was easy. So rare....
Lo-Fi Version | Time is now: 6th June 2024 - 03:38 PM |
