| Mueller |
Aug 4 2005, 02:06 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
| Mark Henry |
Aug 4 2005, 02:14 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Yep the drag racers did this...if you look at the cylinders they have no fins or water jacket...drag race only.
I know I have that mag (Hot VW's) but my scanner is down. They were ruled illegal by the racing rules (PRA?) by the next season. If you raced and did this your teen they would rule it illegal PDQ or at least bump you up a class or two. |
| Tom Perso |
Aug 4 2005, 02:55 PM
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Couldn't you just run waterboxer heads? I know they user waterboxer cases and lower ends with T1 heads, the Oxyboxer? Isn't that right?
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Tom |
| bondo |
Aug 4 2005, 02:57 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Wasserboxers use type1 crank spacing.. it'd work on a type1 but not a type4. |
Lo-Fi Version | Time is now: 29th April 2026 - 11:11 PM |
