74forsche |
Newbie ![]() Group: Members Posts: 49 Joined: 6-November 20 From: castle rock washinton Member No.: 24,848 Region Association: Pacific Northwest ![]() |
These front turn signal replacements are 3d printed poly carbonate carbon fiber housings with 3 leds. The bottom led is the running light. Top two are the turn signal. The housing slides into the stock inner. You remove the stock plug in for the in candescent bulb and plug the leds into the stock harness. Our housing seals against the stock seal. You can use them with or without the stock lens. They are available in the euro layout...bottom led white and upper 2 leds amber.....or US all three amber. Or website https://w3dparts.com is set up to order.
We are developing an entire matchibg tailight housing replacement as well. Let me know if you have questions! Attached thumbnail(s) ![]() ![]() ![]() |
74forsche |
These front turn signal replacements are 3d printed poly carbonate carbon fiber housings with 3 leds. The bottom led is the running light. Top two are the turn signal. The housing slides into the stock inner. You remove the stock plug in for the in candescent bulb and plug the leds into the stock harness. Our housing seals against the stock seal. You can use them with or without the stock lens. They are available in the euro layout...bottom led white and upper 2 leds amber.....or US all three amber. Or website https://w3dparts.com is set up to order. We are developing an entire matching tailight housing replacement as well. Let me know if you have questions! Hyperlink added for our website. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
However nice your product is your sales pictures are lacking. Please take pictures on a nice car. A side shot profile is also important.
74forsche |
Well I dont have a nice 914 to show these on. Here are a couple of side shots assembled. These are much brighter than stock and easy to install. We are a small startup. My son and I are developing an entire light package for the 14's. All custom and leds.
Attached thumbnail(s) ![]() ![]() |
74forsche |
Here are a couple pics to show the install. Remove the bulb receptle and push the wires through and connect to stock wires.
74forsche |
The price for a pair is 290$ plus shipping unless you live in Washington state then sales taxes apply. Payment method is through our website store. https://w3dparts.com
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Reminds me of Felix's neo914 approach. I think he is still around and can be contacted through the site.
http://www.914world.com/bbs2/index.php?sho...7568&st=180 |
JeffBowlsby |
A couple thoughts. Our group typically very much appreciates and encourages innovation, creativity and the efforts to make 914 improvements and alternative available. You've hit on those so don't be discouraged.
Some may see these as unconventional and it may take awhile for folks to consider and determine if they like them or not. Others may see these as an alternative solution to a non-problem. $290 a pair feels a bit steep for a plastic piece with LEDs but not outrageous given what they are or what they do. Be sure they are high quality for that price point or how to reduce the price. Many folks here have very nice quality 914s...if you put out a request, someone may be willing to mount your pieces and take quality photos. Your photos posted so far are typical for what we often see here for prototype mockups...nothing to be concerned about. To make the most of marketing them get excellent quality photos. Constructive feed back, my opinions only: Do we understand that your polymer housing inserts into the factory housing? Why not just make it to replace the factory housing? Does your housing need a reflective coating to bounce light out? The thickness of the flange to the car can be seen between the lens and car body, and the complete assembly looks inelegant. Can you reduce that so that the flange disappears visually? I am not familiar enough with LED tech - what if any additional electronics are needed...any black boxes needed that need to be zip tied somewhere? Are the factory rubber covers still used? What are the electrical connections to the chassis harness like, any mods to the harness needed? |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
A couple thoughts. This group typically very much appreciates and encourages innovation, creativity and the efforts to make 914 improvements and alternative available. You've hit on those so don't be discouraged. Some may see these as unconventional and it may take awhile for folks to consider and determine if they like them or not. Others may see these as an alternative solution to a non-problem. $290 a pair feels a bit steep for a plastic piece with LEDs but not outrageous given what they are or what they do. Be sure they are high quality for that price point or how to reduce the price. Many folks here have very nice quality 914s...if you put out a request, someone may be willing to mount your pieces and take quality photos. Your photos posted so far are typical for what we often see here for prototype mockups...nothing to be concerned about. To make the most of marketing them get excellent quality photos. Constructive feed back, my opinions only: Do we understand that your polymer housing inserts into the factory housing? Why not just make it to replace the factory housing? Does your housing need a reflective coating to bounce light out? The thickness of the flange to the car can be seen between the lens and car body, and the complete assembly looks inelegant. Can you reduce that so that the flange disappears visually? I am not familiar enough with LED tech - what if any additional electronics are needed...any black boxes needed that need to be zip tied somewhere? Are the factory rubber covers still used? What are the electrical connections to the chassis harness like, any mods to the harness needed? (IMG:style_emoticons/default/agree.gif) Well stated. At that price point, I'd very much like to see an option to replace the existing buckets completely with a pre-wired dual circuit setup to accommodate the Euro lens properly with turn signal on top and running lamp on the bottom. Would be worth the $$ to avoid the Euro dual bulb fabrication work. Could it also be that the plastic LED / housing assembly would weight less than the OEM die cast buckets? Very much like the idea that OP is out there trying to come up with better solutions for us. |
74forsche |
A couple thoughts. Our group typically very much appreciates and encourages innovation, creativity and the efforts to make 914 improvements and alternative available. You've hit on those so don't be discouraged. Some may see these as unconventional and it may take awhile for folks to consider and determine if they like them or not. Others may see these as an alternative solution to a non-problem. $290 a pair feels a bit steep for a plastic piece with LEDs but not outrageous given what they are or what they do. Be sure they are high quality for that price point or how to reduce the price. Many folks here have very nice quality 914s...if you put out a request, someone may be willing to mount your pieces and take quality photos. Your photos posted so far are typical for what we often see here for prototype mockups...nothing to be concerned about. To make the most of marketing them get excellent quality photos. Constructive feed back, my opinions only: Do we understand that your polymer housing inserts into the factory housing? Why not just make it to replace the factory housing? Does your housing need a reflective coating to bounce light out? The thickness of the flange to the car can be seen between the lens and car body, and the complete assembly looks inelegant. Can you reduce that so that the flange disappears visually? I am not familiar enough with LED tech - what if any additional electronics are needed...any black boxes needed that need to be zip tied somewhere? Are the factory rubber covers still used? What are the electrical connections to the chassis harness like, any mods to the harness needed? Thanks for the response. The factory lens does ride slightly higher. With our part under it. Our design can be used with or without a lens. It incorporates the factory bucket to easily mount it. It does plug and play to the factory wires after removing the incandescent bulb receptacle. The boot on the stock harness can be left in place. I would love for someone to bring their car to me to test it and review. I live in Washington state. |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,612 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
I’ll tell you what I really hope you take a shot at: flush fit side markers that use the OE location.
Regarding your turn signal prototype, fitting the lens with the gasket on the wrong side is gonna make for foggy lenses. I think you’ve got some good feedback on revisions that will make this part look fully developed. |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,590 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I think surface finish is also something you will want to look into. At this price point people will expect nice finishes, not the typical layered 3D printed parts.
Per rules, we aren't supposed to comment on add, but this could have been posted in the garage like new developments other members vendors do, not necessarily as an add per say. Good luck with your venture! (IMG:style_emoticons/default/smile.gif) |
74forsche |
A couple thoughts. This group typically very much appreciates and encourages innovation, creativity and the efforts to make 914 improvements and alternative available. You've hit on those so don't be discouraged. Some may see these as unconventional and it may take awhile for folks to consider and determine if they like them or not. Others may see these as an alternative solution to a non-problem. $290 a pair feels a bit steep for a plastic piece with LEDs but not outrageous given what they are or what they do. Be sure they are high quality for that price point or how to reduce the price. Many folks here have very nice quality 914s...if you put out a request, someone may be willing to mount your pieces and take quality photos. Your photos posted so far are typical for what we often see here for prototype mockups...nothing to be concerned about. To make the most of marketing them get excellent quality photos. Constructive feed back, my opinions only: Do we understand that your polymer housing inserts into the factory housing? Why not just make it to replace the factory housing? Does your housing need a reflective coating to bounce light out? The thickness of the flange to the car can be seen between the lens and car body, and the complete assembly looks inelegant. Can you reduce that so that the flange disappears visually? I am not familiar enough with LED tech - what if any additional electronics are needed...any black boxes needed that need to be zip tied somewhere? Are the factory rubber covers still used? What are the electrical connections to the chassis harness like, any mods to the harness needed? (IMG:style_emoticons/default/agree.gif) Well stated. At that price point, I'd very much like to see an option to replace the existing buckets completely with a pre-wired dual circuit setup to accommodate the Euro lens properly with turn signal on top and running lamp on the bottom. Would be worth the $$ to avoid the Euro dual bulb fabrication work. Could it also be that the plastic LED / housing assembly would weight less than the OEM die cast buckets? Very much like the idea that OP is out there trying to come up with better solutions for us. It is already wired to have a running light in the bottom and the top 2 blinkers. I also have clears for the bottom to use with a euro lens. |
74forsche |
A couple thoughts. This group typically very much appreciates and encourages innovation, creativity and the efforts to make 914 improvements and alternative available. You've hit on those so don't be discouraged. Some may see these as unconventional and it may take awhile for folks to consider and determine if they like them or not. Others may see these as an alternative solution to a non-problem. $290 a pair feels a bit steep for a plastic piece with LEDs but not outrageous given what they are or what they do. Be sure they are high quality for that price point or how to reduce the price. Many folks here have very nice quality 914s...if you put out a request, someone may be willing to mount your pieces and take quality photos. Your photos posted so far are typical for what we often see here for prototype mockups...nothing to be concerned about. To make the most of marketing them get excellent quality photos. Constructive feed back, my opinions only: Do we understand that your polymer housing inserts into the factory housing? Why not just make it to replace the factory housing? Does your housing need a reflective coating to bounce light out? The thickness of the flange to the car can be seen between the lens and car body, and the complete assembly looks inelegant. Can you reduce that so that the flange disappears visually? I am not familiar enough with LED tech - what if any additional electronics are needed...any black boxes needed that need to be zip tied somewhere? Are the factory rubber covers still used? What are the electrical connections to the chassis harness like, any mods to the harness needed? (IMG:style_emoticons/default/agree.gif) Well stated. At that price point, I'd very much like to see an option to replace the existing buckets completely with a pre-wired dual circuit setup to accommodate the Euro lens properly with turn signal on top and running lamp on the bottom. Would be worth the $$ to avoid the Euro dual bulb fabrication work. Could it also be that the plastic LED / housing assembly would weight less than the OEM die cast buckets? Very much like the idea that OP is out there trying to come up with better solutions for us. It is already wired to have a running light in the bottom and the top 2 blinkers. I also have clears for the bottom to use with a euro lens. I put male blade connectors on the part they plug directly into the factory harness. The factory bucket weighs so little and works well with my part, it retains the factory seal. Our assembly completely seats over the factory seal. It raise the factory lens very little I can look into hiding the lip under the lens. |
74forsche |
I think surface finish is also something you will want to look into. At this price point people will expect nice finishes, not the typical layered 3D printed parts. Per rules, we aren't supposed to comment on add, but this could have been posted in the garage like new developments other members vendors do, not necessarily as an add per say. Good luck with your venture! (IMG:style_emoticons/default/smile.gif) As far as painting goes I would not tackle that. That is professional painter territory! |
74forsche |
I’ll tell you what I really hope you take a shot at: flush fit side markers that use the OE location. Regarding your turn signal prototype, fitting the lens with the gasket on the wrong side is gonna make for foggy lenses. I think you’ve got some good feedback on revisions that will make this part look fully developed. We have talked about side markers. I will work on it. An o ring gasket can be fitted between the lens and our housing. |
74forsche |
We are revising our price to 230$ if you are are someone who wants to use a factory lens over our part we are working on a revision to completely hide our housing under the lens.
Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
We are revising our price to 230$ if you are are someone who wants to use a factory lens over our part we are working on a revision to completely hide our housing under the lens. Can you post two pics from about 10ft away from the front and side of your product on the vehicle? In other words, I personally like the design and would consider buying a set, but I'd like to see what they look like w/o a lens from a distance. Thanks....and nice job! As previously posted by someone else, I think if you completely eliminated the stock bucket, you might even have more interest. Seems like it would be a good place to reduce weight. |
74forsche |
We are revising our price to 230$ if you are are someone who wants to use a factory lens over our part we are working on a revision to completely hide our housing under the lens. Can you post two pics from about 10ft away from the front and side of your product on the vehicle? In other words, I personally like the design and would consider buying a set, but I'd like to see what they look like w/o a lens from a distance. Thanks....and nice job! As previously posted by someone else, I think if you completely eliminated the stock bucket, you might even have more interest. Seems like it would be a good place to reduce weight. It is easy to delete the stock bucket with with our part an upper and lower backer is all it would take. I can incorporate that but it will make install a little more difficult. I will post your requested pics soon! |
74forsche |
Lo-Fi Version | Time is now: 10th June 2024 - 10:17 AM |
