> facet fuel pump, which one?
doobie123
post Aug 2 2022, 05:17 PM
hi all,
i'm working on a 1975 914, 1.8.
there is a facet fuel pump in the car that needs replacimg. i wanted to order one from auto atlanta, (great place by the way) but they have discontinued them.
looking on mine, i can't find a model number.
anyone out there know which one is the correct one?
thanks
Replies(1 - 15)
nditiz1
post Aug 2 2022, 05:40 PM
QUOTE(doobie123 @ Aug 2 2022, 04:17 PM) *
hi all,
thanks
I'm going to assume you are running carbs?
post Aug 2 2022, 06:02 PM
Resident German
There is no correct one since no 914 ever came with one.
When i had my carbed 2056, i ran a CB Performance rotary pump which was much, much quieter.
https://www.cbperformance.com/product-p/3193.htm
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1659484940.1.jpg)
bbrock
post Aug 2 2022, 06:06 PM
I think Facet pumps were outlawed under the Geneva Convention against torture. (IMG:style_emoticons/default/wacko.gif)
nditiz1
post Aug 2 2022, 06:10 PM
@sirandy - that's where I was going with that, this is probably the best pump to run whether you are in a 4 or a 6 and have carbs.
URY914
post Aug 2 2022, 06:16 PM
Andy is spot on. (IMG:style_emoticons/default/beerchug.gif)
mb911
post Aug 2 2022, 06:51 PM
QUOTE(nditiz1 @ Aug 2 2022, 04:10 PM) *
Yup I run the same one.
theer
post Aug 3 2022, 07:21 AM
I agree with the others on fuel pumps- I have the same on my carbed 1.9l, but I do have a Facet pump you can have for the cost of shipping, if you’re just trying to get it running.
The Facet I have will only work for carbs, by the way. FI needs much higher pressure and a return line.
930cabman
post Aug 3 2022, 07:39 AM
has anyone used the Mr Gasket 3psi pump?
rhodyguy
post Aug 3 2022, 08:47 AM
Remember to purchase a fuel pressure regulator when you buy the facet. Figure out a way to isolate the pump if mounted on a metal surface. The rattling is very annoying.
Ansbacher
post Aug 3 2022, 01:20 PM
Two questions:
Why are they still manufacturing freaking Facet Fuel Pumps! ???
Why are people still buying them???
Ansbacher
parrish911
post Aug 3 2022, 01:47 PM
In my humble opinion, best to run a rotary pump, a fuel pressure regulator (I used the one from PMO) and a return line. I did this with a dual carb set-up (40 IDF)
dr914@autoatlanta.com
post Aug 3 2022, 03:17 PM
we have them under a different part number now r90160810600
hi all,
thanks
Dave_Darling
post Aug 3 2022, 10:57 PM
914 Idiot
QUOTE(Ansbacher @ Aug 3 2022, 12:20 PM) *
Because people buy them.
Because they're cheap.
--DD
doobie123
post Aug 5 2022, 05:25 PM
hey ya'll thanks for the replies.
so i'm thinking that the thing to do is ditch the facet and go with the rotary.
got it!
thanks for helpin the new guy out!
SKL1
post Aug 5 2022, 11:12 PM
Definitely the rotary pump as mentioned, and a fuel regulator.
(and we don't need another 10 page thread carbs vs FI)
- Lo-Fi Version Time is now: 22nd October 2026 - 01:35 AM
