1170 mile cv joint failure |
mb911 |
Aug 25 2022, 01:52 PM
914 Guru Group: Members Posts: 6,879 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Well 1170 miles on my cv joints. Driving last evening took off slow then gassed it in first. Let off shift to second and hit the gas again and pop. Cv cage broke.. well that sucks.. anyway time to replace with some other setup. I have some extra CVS and will install but wanting a more permanent solution.
For reference 2.4 -6 with S pistons, solex cams, ported heads. |
930cabman |
Aug 25 2022, 02:12 PM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
cage may have had a small crack? was it a new joint?
mb911 |
Aug 25 2022, 02:32 PM
Eric_Shea |
Aug 25 2022, 02:42 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Where did you get them? What Brand? What -6 Engine?
Steve |
Aug 25 2022, 02:48 PM
914 Guru Group: Members Posts: 5,611 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Well 1170 miles on my cv joints. Driving last evening took off slow then gassed it in first. Let off shift to second and hit the gas again and pop. Cv cage broke.. well that sucks.. anyway time to replace with some other setup. I have some extra CVS and will install but wanting a more permanent solution. For reference 2.4 -6 with S pistons, solex cams, ported heads. They look like 914-4 CV joints. I would upgrade to 100mm CV joints. |
SirAndy |
Aug 25 2022, 03:12 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Where did you get them? What Brand? What -6 Engine? (IMG:style_emoticons/default/agree.gif) If these are repurposed T1 CVs, those seem to have a tendency to explode when used in a 914. Seen it before ... (IMG:style_emoticons/default/icon8.gif) |
Eric_Shea |
Aug 25 2022, 03:16 PM
Sorry, I didn't see the 2.4S engine in the first thread...
I'd go this route: http://www.914world.com/bbs2/index.php?showtopic=91963 |
ClayPerrine |
Aug 26 2022, 08:04 AM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
From outside to inside.
1. 1976 911 Hub 2. 1976 922 stub axle 3. 1985 944 turbo CV joint. 4. 914-4 axle - turn it in the lathe and add about 15mm to the space beyond the splines. 5. 1985 944 turbo CV joint 6. 1976 911 coarse splined drive flanges. The 944 turbo CV joint is a six bolt joint that is much thicker than a 914 cv joint, but the internal splines are the same as a 914-4. So the CV joint is capable of handling way more power than a stock 4 cylinder joint. The axle has to be modified to accommodate the thicker 944 turbo CV joint. The 76 911 hub, stub axle and drive flange are the same bolt pattern as the 944 turbo CV, and they use the same outer wheel bearing as a 914. So this all bolts together. You have to use 944 turbo CV joint gaskets and CV bolts. The coarse splined drive flanges come from an early 915 transmission, but they will bolt into a 901 transmission with no modification. You can use 944 turbo stub axles, but you have to add a spacer on the stub axle or the bearing won't tighten up. Hope that helps. Clay |
mb911 |
Aug 26 2022, 08:10 AM
Thanks.. a few things I decided after this happened.
A. I have to many cars to maintain. My sons have 5 total cars themselves and 2 of them are 944s B. I have a non finished 928s4 that needs to go to a new home to get some space back C. Going to just put a stock cv back on and take it easy the rest of the driving season. D. Going to a 911/914 setup this winter. @mepstein has already provided most the parts to make this happen. I just need some time. E did I already say I have to many cars to maintain lol? Anyone need a really nice 928s4 project (IMG:style_emoticons/default/biggrin.gif) |
Jack Standz |
Aug 26 2022, 10:40 AM
Member Group: Members Posts: 281 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
Yes, a 928 S4 would be a nice project and yes, I want one (already have a complete drive train from a 928).
But, I have too many cars and too many projects. So, I guess I don't need one. (IMG:style_emoticons/default/dry.gif) |
mb911 |
Aug 26 2022, 02:31 PM
Yes, a 928 S4 would be a nice project and yes, I want one (already have a complete drive train from a 928). But, I have too many cars and too many projects. So, I guess I don't need one. (IMG:style_emoticons/default/dry.gif) Well I have it listed on market place and have some great walk around and start up videos. https://www.facebook.com/marketplace/item/435211755239175/ |
Lo-Fi Version | Time is now: 7th June 2024 - 01:52 AM |
