| Wadesbrain |
Sep 9 2022, 12:50 PM
Newbie ![]() Group: Members Posts: 29 Joined: 29-April 19 From: Mount Bethel, Pa Member No.: 23,073 Region Association: North East States |
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need?
| ClayPerrine |
Sep 9 2022, 12:53 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Someone here probably has the complete wiring harness from a car that was parted out. Just put a wanted to buy ad up in the classifieds.
| FlacaProductions |
Sep 9 2022, 12:56 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,295 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I got great product from Restoration Design. Peter Kocandrle @ wiring@restoration-design.com helped me.
| Wadesbrain |
Sep 9 2022, 01:14 PM
Thanks for the replies. Im actually looking to do the whole thing myself. I can't weld or grind in my garage over the winter and I have the space and time to lay out a new one. I just need parts. The only option if I can't find original colors is to make up new ones and keep a record to translate. I would rather not do that.
| gord |
Sep 9 2022, 01:16 PM
Member ![]() ![]() Group: Members Posts: 78 Joined: 30-May 20 From: Toronto, Canada Member No.: 24,334 Region Association: Canada |
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need? Check out 4R Customs Wire — they're like the Belmetric of wiring. https://4rcustomswire.com/ |
| Wadesbrain |
Sep 9 2022, 01:25 PM
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need? Check out 4R Customs Wire — they're like the Belmetric of wiring. https://4rcustomswire.com/ That is what I'm looking for! Thanks. |
| 914Sixer |
Sep 9 2022, 02:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,606 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
NOS one at Asse Sales $1500 for 1971
| Wadesbrain |
Sep 9 2022, 04:09 PM
| FlacaProductions |
Sep 9 2022, 04:21 PM
| 914-Kazoo |
Sep 10 2022, 05:05 PM
Newbie ![]() Group: Members Posts: 45 Joined: 19-August 20 From: Kalamazoo, MI Member No.: 24,609 Region Association: Upper MidWest |
| 914-Kazoo |
| DennisV |
Sep 10 2022, 06:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,048 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need? When I decided to build my own wiring harness to add heated seats to my Boxster, I bought wire from Allied Wire and Cable. They offer TYPE TXL Extra Thin Wall (XLP) AUTOMOTIVE PRIMARY WIRE. It is a low tension primary cable that is meant for the following applications. * For use in automotive applications where small diameter and minimal weight is desirable. * Meets requirements of SAE J-1560 (now contained in J-1128). * Recommended temperature range -51 C to +125 C. * Available in solid colors and stripes with optional custom printing and/or numbering available. * Also meets Ford (Mil-123A) and Chrysler (MS-8288) That was a few years ago but I suspect it's still available. |
| waltonsm |
Sep 11 2022, 06:31 AM
Member ![]() ![]() Group: Members Posts: 93 Joined: 27-June 14 From: United States Member No.: 17,561 Region Association: Pacific Northwest
I’ve got 99% of the wiring harness I pulled from my car that I was planning to sell to someone who needed a whole one. I took it out in one piece and it hasn’t been painted over. Came out in one piece, only thing I cut off was the fuel tank sender connector.
| johnorm |
Sep 17 2022, 10:08 AM
Newbie ![]() Group: Members Posts: 28 Joined: 28-October 18 From: Canada Member No.: 22,610 Region Association: Canada |
I'm getting ready for winter time projects for my '70 1.7. My current harness is totally roached, burned, poorly spliced and painted over. Does anyone have a supplier for original color spools of wire and perhaps connectors, grommets, or plugs that I would need? Check out 4R Customs Wire — they're like the Belmetric of wiring. https://4rcustomswire.com/ That is what I'm looking for! Thanks. Also check out ACDCSUPPLY on eBay (they and 4R both sell GXL/TXL striped wire). For connectors try Digi-key, I would suggest you want to try TE Connectivity AMP quick connection uninsulated crimp connectors. Some of the one's I have used are Part # Gauge Tab Width and Style[/b][u] 180351-2 10-12ga. 0.25 Single Female 62998-1 8-10ga. 0.25 Single Female 63365-1 10-14ga. 0.25 Single Female 41727 12-16ga. 0.25 Single Female 41202 14-18ga. 0.25 Single Female 63093-1 14-18ga. 0.11 Single Female / Narrow Tab 42068 18-22ga. 0.11 Single Female / Narrow Tab 61944-2 14-18 0.25 RCPT/TAB (one Female / One Male TAB) 61988-1 18-22ga. 0.25 RCPT/TAB (one Female / One Male TAB) 61386-1 16-20ga. 0.25 Ring Connector 3mm stud 160163-2 10-12ga. 0.25 Ring Connector for 4mm stud |
Lo-Fi Version | Time is now: 8th November 2026 - 12:16 AM |
