Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 901.106.011.00, Fan housing Complete - 914-6
DennisV
post Sep 16 2022, 02:30 PM
Casting number 901.106.101.5R with a depth of 86 mm (lip to alternator mount face). Made from die cast Magnesium.
Be aware that between 1965 and 1989, there were no less than 8 different 911 fan housings. Varying in material (aluminum, magnesium), diameter (250, 245, 226), and depth (86, 95, 106). Thank you Tom Butler..
There were two different parts made with 901.106.101.5R casting number. One with 86 mm deep housing for a 55 amp alternator or a 95 mm deep version for a 70 amp alternator (this would be part number: 911.100.008.00).
So if you’re about a 914-6, you should be looking for casting number 901.106.101.5R with a depth of 86 mm (lip to alternator mount face). As the 914-6 engine has 770W 14v generator which equates to 55 amps. Shared with 1969-74 911 (with coil studs).
- Lo-Fi Version Time is now: 11th July 2025 - 12:00 PM
