need to replace door seal, which seal is this? |
brant |
Sep 27 2022, 10:50 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
its on the chassis... not the actual door.
got confused looking at 914 rubber and didn't want to order the wrong seal. can anyone help confirm, which seal this is.... which one I need to order? thanks in advance. Attached thumbnail(s) |
Mikey914 |
Sep 27 2022, 12:10 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That we call the inner door seal
$34 gets you a set left and right https://914rubber.com/inner-door-seal-set-1 Attached thumbnail(s) |
dr914@autoatlanta.com |
Sep 27 2022, 01:19 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
b91453182110
NARP74 |
Sep 27 2022, 03:43 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Buy 20 and save! Sell them to all your friends... At least that one looks easier to install than some of the others.
Mikey914 |
Sep 28 2022, 10:52 PM
It will require you to remove the carpet strip, but pretty easy
BTW I have the black Nickel screws that will not corrode for the strips if you need them. |
Lo-Fi Version | Time is now: 11th June 2024 - 04:05 AM |
