123 Ignition App Dashboard Accuracy, Blue Tooth Version |
Highland |
Oct 7 2022, 02:58 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Wondering if anyone can comment on the accuracy of 123 Ignition's dashboard gauge accuracy. Is the Bluetooth connection causing error?
When I'm at steady idle, my stock Tach reads about 50~100 rpm higher and at steady cruise (3000 rpm) my Tach reads about 200 rpm higher. Also curious about amp, V, vacuum and oil temp gauges. Is the amp only for coil/ignition load? |
nditiz1 |
Oct 7 2022, 03:50 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I have always assumed my analog gauges were off.
Lockwodo |
Oct 7 2022, 05:22 PM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
I have always assumed my analog gauges were off. (IMG:style_emoticons/default/agree.gif) Many timing lights have a built in tach which could be used to verify actual rpm. |
VaccaRabite |
Oct 7 2022, 05:42 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The stock gauges on my engine read higher then the electronic gauges I have via Microsquirt. The tach is often off by 200 rpm at idle compared by what I'm seeing when I'm data logging. And given the ECU is getting engine speed from the crank, I'm believe that over the 50 year old analog gauge.
Zach |
Lo-Fi Version | Time is now: 6th June 2024 - 09:20 PM |
