> 914 and 911 Dash Climate Controls, interchangeable?
ericoneal
post Dec 9 2022, 11:56 PM
Specifically for the 1973 era? At the very least, are the dash units the same size? Trying to fill a hole. Thanks
Replies(1 - 3)
914Sixer
post Dec 10 2022, 06:13 AM
NO. Different electrical connection. 911 has plug on it.
ClayPerrine
post Dec 11 2022, 07:53 AM
The 911 ventilation controls are the same size as the 914 controls. There are different variations in the actual cable and electrical connections. So if all you are trying to do is plug the hole, then it will fit. Otherwise you may have to do some creative modification to get it hooked up.
I bought a 76 911 control head and used pieces from it in a 914 control head because the top lever in the 911 is split in two. That way the blower can be run separate from the cable control. I can use the top lever cable to run the recirculation door, and still be able to run the blower in my stalled AC install.
Clay
6er
post Dec 12 2022, 05:53 PM
Interesting for mine
- Lo-Fi Version Time is now: 31st July 2025 - 02:39 AM
