Any pictures of a stock return spring on the throttle body? |
brant |
Dec 26 2022, 09:01 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I’m replacing my throttle cable
The aux return spring does not line up straight and I’m guessing is a PO decision What are s a factory location/routing for the stock return spring? It may be time to find one and put this back the right way Brant |
Garland |
Dec 26 2022, 10:13 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Here you go!
brant |
Dec 26 2022, 10:19 AM
Craigers17 |
Dec 26 2022, 11:12 AM
Senior Member Group: Members Posts: 742 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
brant |
Dec 26 2022, 11:47 AM
Perfect
Thank you so much Mine has been wrong for years I see Good time to fix it Thank you!!!!! |
930cabman |
Dec 26 2022, 11:53 AM
Advanced Member Group: Members Posts: 3,140 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
NARP74 |
Dec 26 2022, 12:02 PM
Senior Member Group: Members Posts: 1,073 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Perfect Thank you so much Mine has been wrong for years I see Good time to fix it Thank you!!!!! Another case of a previous "mechanic", it's a miracle any of our machines run after a 1/2 century of backyard guys fooling around where they shouldn't. Everything I touch on mine I have to re-learn what is the correct way. I think what I have is correct until I see pictures of the way it should be. Always interesting. |
Craigers17 |
Dec 26 2022, 12:10 PM
Perfect Thank you so much Mine has been wrong for years I see Good time to fix it Thank you!!!!! That pic was from a 74' that I sold last year. I can't confirm that everything is 100% stock, but that's how it looked after I cleaned everything up & reinstalled. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 10:39 AM |
