> Tire recommendations?
rjames
post Jan 6 2023, 06:10 PM
I'm made of metal
Looking to replace my 10 year old Eagle GTs. They are 195/60/15 but seems like only 195/65/15s are available now when looking briefly. They will go on 4 lug Mahles under stock fenders. Pretty sure I couldn't get 205s under the fenders without rolling them (not interested in doing so) because it's already pretty tight on one side.
What does the 914 brain trust recommend these days?
3 Pages V  1 2 3 >
Replies(1 - 19)
live free & drive
post Jan 6 2023, 08:43 PM
I think these might be worth a try:
https://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes
Make sure they are Sprint (+) or Sprint plus - there are other variations of the Vredestein Sprint name and they are not the same...
PS these are a new tire intended for the "classics" market
steuspeed
post Jan 6 2023, 11:18 PM
195/65/15 is the correct diameter. Choices are very limited though.
wonkipop
post Jan 7 2023, 12:56 AM
here we go again. tyres!
but.......
go skinny and sh#t yourself. its so much fun. and the steering is so light.
Geezer914
post Jan 7 2023, 06:08 AM
Geezer914
How cold does it get in WA? Those are summer tires and they will crack if run in cold weather.
Jamie
post Jan 7 2023, 09:15 AM
QUOTE(steuspeed @ Jan 6 2023, 09:18 PM) *
I've been running Michelin Exalto A/S 205/65/15's on stock steel 5.5"rims for several years with no clearance problems on original body. Diameter is very close to stock with very little speedo error, but don't know if they are still available since originally purchased from Tire Rack.
Van B
post Jan 7 2023, 11:11 AM
QUOTE(wonkipop @ Jan 7 2023, 01:56 AM) *
but.......
My man! (IMG:style_emoticons/default/agree.gif)
dr914@autoatlanta.com
post Jan 7 2023, 11:15 AM
michelin now makes a very reasonably priced 195/65x15 that we are putting on the cars. It is the exact size for keeping the speedometer reading correctly with an extra bit of width over the standard 165x15
QUOTE(rjames @ Jan 6 2023, 05:10 PM) *
bbrock
post Jan 7 2023, 11:27 AM
I've got 7K miles on my 195/65/15 Firehawk AS tires now and love them. Quiet, nimble, and plenty of grip for me. Get good reviews in the performance all weather tire category. I like to hit the twisties pretty hard and the tires have more grip than my nerve. I like them so much I'll probably put them on the DD when it is time for new tires.
Ditto what @Geezer914 said. I looked at summer performance tires when I was shopping but our evening temps in summer are often below the minimum those tires were designed to run at. Just make sure to check the fine print.
Geezer914
post Jan 7 2023, 01:05 PM
Geezer914
I am running Firestone Fire Hawks AS also in 195/60-15. Looks like they no longer offer that size. That was the only performance tire offered in that size.
Cairo94507
post Jan 7 2023, 01:20 PM
Michael
I really like Michelin tires and am probably going to order a set of the 195x65x15 Primacy A/S for my car. I currently have 195x55x15 and really want to get a bit taller sidewall. Also, though stupid, it is a good looking tire without huge graphics on it. A full set delivered from Tire Rack is $630.60. (IMG:style_emoticons/default/beerchug.gif)
Van B
post Jan 7 2023, 02:56 PM
QUOTE(dr914@autoatlanta.com @ Jan 7 2023, 12:15 PM) *
What tire specifically?
So, many people on this forum say 195/65-15 is correct for the speedo, but my GPS testing says not. All brands in this size are right at 25” diameter which yields a 5mph fast indication error.
A 165HR15 by comparison is a 25.4” diameter, which is still shy of what you would need to make indicated = GPS actual.
A 26.5” diameter is what you need to get your speedo to read true… which is a 185VR15
bbrock
post Jan 7 2023, 04:27 PM
QUOTE(Geezer914 @ Jan 7 2023, 12:05 PM) *
That size is still showing on the Firestone site, but Firehawk AS no longer comes up on Tire Rack.
wonkipop
post Jan 7 2023, 04:58 PM
QUOTE(Van B @ Jan 7 2023, 02:56 PM) *
which is what you can get as a pirelli cinturato remake.
its what all the early 911 guys now run down here.
its not quite a sh#t yourself tyre as the 165 XAS i run but i hear the steering is still beautifully light.
expensive as hell though.
although mayber vredestein make that size?
Van B
post Jan 7 2023, 05:28 PM
Only vred or the coker tire remakes by my searching. That’s why I’m opting for the vred tires. I trust them to be more consistent in quality and they are a better price point and availability.
wonkipop
post Jan 7 2023, 05:59 PM
@Van B
this is the one the 911 guys use down here.
they will have a knife fight outside the tyre shop to take a set and then the tyre guy takes the winner's wallet, empties it and sets it on fire with a blow torch.
pandemic aftermath means they trickle in.
25.67 inch diameter fitted if you convert the table.
post Jan 7 2023, 09:46 PM
QUOTE(Van B @ Jan 7 2023, 12:56 PM) *
according to tiresize.com 165/80/15 is 25.4 185/70 15 is 25.2 and 195/65.15 is 25.0 with a speedometer reading of minus 1.5 mph with the 195 at 90 mph or 88.6
Van B
post Jan 7 2023, 10:24 PM
QUOTE(914043 @ Jan 7 2023, 10:46 PM) *
None of that is relevant until you asses your current speedometer error via GPS.
Ex: OE tire size for my 996 C2 is 265/35R18. But a 275/40R18 gives me an exact match to GPS on my speedometer.
Van B
post Jan 7 2023, 10:26 PM
Your speedo gear is also clocking your odometer so, I’m not looking to give away ghost miles. Modern cars using can bus systems can be internally calibrated, but on our analog rides we have to do it physically.
post Jan 7 2023, 11:02 PM
QUOTE(Van B @ Jan 7 2023, 08:26 PM) *
don't understand your reasoning, in your example what you say is exact shows 1.5 inch difference in height and 5 mph more at 90mph. (IMG:style_emoticons/default/confused24.gif)
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 11:08 AM
