rcautox |
Newbie ![]() Group: Members Posts: 17 Joined: 12-October 20 From: Alaska Member No.: 24,758 Region Association: Pacific Northwest ![]() |
Hi all,
I've been scouring 914 world for help on getting a new-to-me '74 1.8l running. I've reviewed Auto Atlanta's informative video on the 914 fuse & wiring and I think I follow the gist but may have missed things. I've also studied the simplified diagrams on Pelican Parts which have been helpful to understand the 914 layout. What I've done: 1. new battery 2. new ground strap straight to the transmission bolt in the rear of the engine bay 3. cleaned battery connections 4. cleaned the fuse panel When I turn the key the only thing I can see working is the marker lights and the clock. So no fuel pump, no start, etc. Can you all point me to a few areas to tackle first to determine the culprit(s)? |
SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
Seat Belt Interlock ?
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Carbs, FI?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Start at the wiring diagrams. Your Haynes manual has B&W versions with labels for the colors. You can find full-color copies around on the web if you look.
Dig our your voltmeter and start checking for where you have voltage and where you have ground, and where you have neither. --DD |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,168 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Was the car running when you purchased her? Between Google and 914 World you will find a wealth of information. |
rcautox |
Regarding seat belt bypass-I pull the passenger seat, it looks like the bypass has already been addressed? Photo attached
Unfortunately it is FI, have to love 70s FI electrical gremlins…. I bought it and a 72 from the previous home owner. She lives next door so easy enough to ping her for info. The 74 ran fine until it just died one day. Her ex thought it was electrical. I’m starting with the simple stuff like battery and grounds. From reading this site I suspect I need to move to the ignition next. I had a VW Vanagon with a 2.0 that also provided unreliable electrical services. I could bridge the starter with a screw driver with the key in the on position. Considered trying this on the 914 but I’m thinking fuel pump not running needs to be addressed? Appreciate the help ![]() |
Van B |
So, two things to check:
1.) With the key on, push on the AFM flapper and see if the fuel pump kicks on. 2.) Now that you have confirmation of fuel flow, try to jump start the car across the starter terminals. If the car starts, then we can narrow the scope of your starting issues. IMPORTANT: Don't pedal the car when starting. Backfires break AFMs. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,015 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Regarding seat belt bypass-I pull the passenger seat, it looks like the bypass has already been addressed? Photo attached Unfortunately it is FI, have to love 70s FI electrical gremlins…. I bought it and a 72 from the previous home owner. She lives next door so easy enough to ping her for info. The 74 ran fine until it just died one day. Her ex thought it was electrical. I’m starting with the simple stuff like battery and grounds. From reading this site I suspect I need to move to the ignition next. I had a VW Vanagon with a 2.0 that also provided unreliable electrical services. I could bridge the starter with a screw driver with the key in the on position. Considered trying this on the 914 but I’m thinking fuel pump not running needs to be addressed? Appreciate the help ![]() @rcautox Yes the interlock relay is bypassed. Check to see if you have power in the yellow wire as is comes from the ignition switch and then out of that connector. If you do check the fuel pump fuse on the replay board. It is the fuse closest to the back of the car. rotate all the other fuses in the fuse panel They often corrode and loose contact. |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,803 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
Regarding seat belt bypass-I pull the passenger seat, it looks like the bypass has already been addressed? Photo attached Considered trying this on the 914 but I’m thinking fuel pump not running needs to be addressed? Appreciate the help ![]() on a stock 1.8 L Jet the fuel pump only runs when cranking. then the AFM unit takes over running the pump once engine fires. does not run with just the ignition on. you can test by taking the air cleaner out and unclipping bottom. leave the AFM plugged in. with the bottom off you should be able to see in to where the AFM flap is. with ignition on push the AFM flap carefully in. you should hear the fuel pump run if its all ok. ah i see @Van B has already instructed. i'd check all the ground points are clean and corrosion free. wiring diagrams can be found here. http://p914-6info.net/Manuals.htm |
rcautox |
Thank you for the detailed suggestions. I gently pushed the AFM flap but no fuel pump. I moved to the yellow wire, no power or continuity. I figured I need to focus my efforts on the ignition switch and I found the relay was unplugged. I now have power to the gauges and the fuel pump kicks on when I push in the flapper.
If I’m reading the wiring diagrams correctly the yellow wire goes from my ignition switch to the starter. So next step I should think is the lack of continuity or power when the ignition is on? The starter does turn over if I jump the terminals. The previous owner left a bunch of parts including a steering column so, along with the oddly unplugged ignition switch, I’m guessing they had identified this as a possible issue. Any advice on how to identify the source of the issue with the yellow wire? |
StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,161 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
On 1.8s, don’t forget the unique dual relay and capacitor pack below the battery.
wonkipop |
Thank you for the detailed suggestions. I gently pushed the AFM flap but no fuel pump. I moved to the yellow wire, no power or continuity. I figured I need to focus my efforts on the ignition switch and I found the relay was unplugged. I now have power to the gauges and the fuel pump kicks on when I push in the flapper. If I’m reading the wiring diagrams correctly the yellow wire goes from my ignition switch to the starter. So next step I should think is the lack of continuity or power when the ignition is on? The starter does turn over if I jump the terminals. The previous owner left a bunch of parts including a steering column so, along with the oddly unplugged ignition switch, I’m guessing they had identified this as a possible issue. Any advice on how to identify the source of the issue with the yellow wire? i'm hopeless at electrical stuff. so not much help. but at least you got a fuel pump that is properly wired in. where is your fuel pump located, still in stock position under engine bay on rhs? having that fuel pump wired in right will help if there is further diagnosis required to get the L jet to run sweet again. someones bound to pipe in with electrical advice who knows what they are talking about. good luck with it. L jets forever. (IMG:style_emoticons/default/beerchug.gif) |
Van B |
Thank you for the detailed suggestions. I gently pushed the AFM flap but no fuel pump. I moved to the yellow wire, no power or continuity. I figured I need to focus my efforts on the ignition switch and I found the relay was unplugged. I now have power to the gauges and the fuel pump kicks on when I push in the flapper. If I’m reading the wiring diagrams correctly the yellow wire goes from my ignition switch to the starter. So next step I should think is the lack of continuity or power when the ignition is on? The starter does turn over if I jump the terminals. The previous owner left a bunch of parts including a steering column so, along with the oddly unplugged ignition switch, I’m guessing they had identified this as a possible issue. Any advice on how to identify the source of the issue with the yellow wire? Good find on the relay. So, does it still not crank with the key? |
rcautox |
Fuel pump is in the front. I pulled the tank, cleaned it out and installed new lines from Tangerine Racing. I know location varies by year but the pump sure looks to be better in the stock location based on wiring and the little recess on the trunk wall.
No start with key. I should get some voltage on the yellow wire under the pax seat with key in the acc/on position? I ask because I’m seeing none. Thinking there may be a short in the wire between ignition and starter or the ignition switch is acting up (which could explain the spare parts and unplugged relay) |
Dave_Darling |
The yellow wire should be getting power only while the key is in the "starting" position. In "run" it should not, otherwise you'd have your starter engaged while driving the car, which is not what you want.
--DD |
wonkipop |
Fuel pump is in the front. I pulled the tank, cleaned it out and installed new lines from Tangerine Racing. I know location varies by year but the pump sure looks to be better in the stock location based on wiring and the little recess on the trunk wall. ah it sounds like you actually have a model year 75 if it has the little recess in trunk wall and fuel pump there. whats the VIN label on the door say for date of manufacture. will have month and year? fairly similar to a 74 model year 1.8 but there are some differences with components. might be relevant to getting it running once you sort out ignition electricals. |
rcautox |
In the starting position I do not have power in the yellow/red stripe wire, I do have power in the yellow wire. Looking at the wiring diagrams I think the yellow/red wire comes from the ignition switch. So either the current connection of the two yellow wires is bad or the ignition switch is bad?
You are correct-it is a 75. Checked the vin and engine # to confirm it’s a 75 with a 1.8l. Good catch for future fixes. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,873 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
In the starting position I do not have power in the yellow/red stripe wire, I do have power in the yellow wire. Looking at the wiring diagrams I think the yellow/red wire comes from the ignition switch. So either the current connection of the two yellow wires is bad or the ignition switch is bad? You are correct-it is a 75. Checked the vin and engine # to confirm it’s a 75 with a 1.8l. Good catch for future fixes. could most likely be the crappy ignition switch ? when mine failed it went from occasional no crank to nothing @ all,some other functions still worked however. Switch cover was cracked @ the spring . |
Dave_Darling |
In the starting position I do not have power in the yellow/red stripe wire, I do have power in the yellow wire. How would you have power in the yellow wire when it isn't in the yellow/red wire? It sounds like something is connected wrong, or we are talking about different wires than I think we are. --DD |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
You have power, key in start position, to the yellow wire in this picture and not to the yellow wire with red stripe, in this picture? At this specific location?
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 3rd July 2025 - 03:16 AM |
