| Rrrockhound |
Mar 5 2023, 03:25 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 30-November 05 From: Delaware, OH Member No.: 5,213 Region Association: None
What is the plastic plug for?
What are the arcs cast into the metal for? And what is the opening cast into the metal (circled) for? ![]() |
| Dlee6205 |
Mar 5 2023, 03:36 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
On some variations, the coil is mounted in that spot vs being mounted on the engine tin. Removing that plastic plug will expose a threaded hole.
| SirAndy |
Mar 5 2023, 04:44 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,560 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
On some variations, the coil is mounted in that spot vs being mounted on the engine tin. Removing that plastic plug will expose a threaded hole. (IMG:style_emoticons/default/agree.gif) Be careful with mounting a modern coil in that spot, they are slightly smaller in diameter as period correct coils and will not fit snug when you use the stock clamp. Without extra padding, they end up rotating and short to the case. Ask me how i know. (IMG:style_emoticons/default/dry.gif) PS: The opening circled is for the hooked end of the stock clamp that holds the coil. |
| 914werke |
Mar 5 2023, 04:50 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,781 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
That is the preferred location to mount the coil vs the top of the tin,
Ive repaired too many top 3/4 tins sections that had been torn from the vibration of the relatively heavy coil mounted atop the tin ...beside that area becomes exceedingly hot. |
| wonkipop |
Mar 5 2023, 05:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,776 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
as noted above holes and ribs are for coil mounting strap.
that is the position for mounting the coil on all VW models that used the engine. 74 on 914 1.8s used this standard VW mounting. not sure about 2.0s arcs in the fan casting are a symbol to indicate which way to point the coil. all visible on a rear engine VW and makes sense. |
Lo-Fi Version | Time is now: 2nd November 2026 - 08:55 AM |
