TrailerParkBoy |
Newbie ![]() Group: Members Posts: 8 Joined: 7-February 23 From: PNW Member No.: 27,145 Region Association: Pacific Northwest ![]() |
Intake seat let go. Ended up resting at angle to valve (odd location, usually they sit flat if loose?) which ended up taking a chunk from top of piston and scuffing cam lobe from pressure created. Much work ahead of us this weekend :-(
![]() ![]() Attached thumbnail(s) ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,670 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Oops! Yup, doesn't look good, probably didn't sound good either.
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,163 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
time for two new heads, these things are now 50 years old and repairing is expensive and then with bad luck another seat will let go
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
That looks wrong in a few ways.
Valve,,, obvious Top of piston pitting, root cause? Lots of white in head, possible lean condition? Rich |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,954 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Looks like it could of been lean as mentioned
Too much head temps and seat would of became loose |
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 719 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
The top of that piston looks really bad. Did you wire brush off all the carbon deposits before you took the photo? If not, then it looks like the metal of that piston has gone bad and the metal is disintegrating.
r_towle |
It’s possible that detonation may have caused this.
TrailerParkBoy |
Thank you for the eye. Great questions. I’ll grab and post more photos this week.
Top of piston - this is untouched, as it was when opened up. Ancient Heads - LN Eng would be nice. Not much out there for options that don’t break bank. |
r_towle |
What budget do you have?
I think AA makes new heads, then LN remachines them. So….buying direct from AA May cost less Or, shop for a used head and piston Eric Shea made a great statement. Don’t need to over think a type 4 motor. |
brant |
I’m guessing it was not running right ?
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Be interesting to see if the rod bearings are beat to death. The tops of the piston have all the hallmarks of detonation/preignition.
TrailerParkBoy |
gnomefabtech |
Member ![]() ![]() Group: Members Posts: 147 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None ![]() |
Looks to me like that valve seat did a dance in there and pitted the piston. I'm guessing that pieces of the head chipped off and also added to the pock mark party. I'm guessing the big dent was caused by the valve being held open and the piston hitting it.
Dropped valve seats are often caused by poorly executed valve jobs where the shop didn't take into account the expanding nature of an air cooled head and didn't fit the seat with enough interference. Or there was a crack or some other event that kicked the seat out of there. If the other cylinders all look good maybe just replace that piston and head. Very unlikely that the rod bearing is damaged unless you can see that the rod got bent. Once you reassemble, check if that piston sits low at TDC because that could mean a bent rod. I'm surprised the cam got damaged without bending the pushrod or bending other valvetrain parts. Check that too! |
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
I had an intake valve seat drop in a Corvair Turbo under boost..
Parts of the seat ended up in other cylinders on that side and some went down the exhaust and ended up in the turbo blades. That was a real mess… |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,055 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
The tops of the piston have all the hallmarks of detonation/preignition. (IMG:style_emoticons/default/agree.gif) |
bludden |
Member ![]() ![]() Group: Members Posts: 57 Joined: 15-June 20 From: Charlotte NC Member No.: 24,380 Region Association: South East States ![]() |
Happened to me a week and a half after I bought my first 914. Got to learn how to remove an engine, with my previous mechanical experience being replacing a Camaro water pump.
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,891 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
Again, reminds me of the importance of AFR and CHT gauges in these cars.
majkos1 |
Member ![]() ![]() Group: Members Posts: 220 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains ![]() |
engine original fuel injection or carb?
Superhawk996 |
Again, reminds me of the importance of AFR and CHT gauges in these cars. Proper tuning will do. I’m not against technology but setting timing properly and reading plugs goes a long way, doesn’t cost much, and doesn’t require exhaust mods and wiring. If technology is wanted to prevent this, need to start looking at knock sensing. On almost every modern vehicle. One of the problems with air cooled engines is all the noise they emit. Very easy for someone not familiar with knock / detonation to think it is a “normal” noise that air cooled engines make. Detonation kills engines fast. What do the other pistons look like? |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
Again, reminds me of the importance of AFR and CHT gauges in these cars. Proper tuning will do. I’m not against technology but setting timing properly and reading plugs goes a long way, doesn’t cost much, and doesn’t require exhaust mods and wiring. If technology is wanted to prevent this, need to start looking at knock sensing. On almost every modern vehicle. One of the problems with air cooled engines is all the noise they emit. Very easy for someone not familiar with knock / detonation to think it is a “normal” noise that air cooled engines make. Detonation kills engines fast. What do the other pistons look like? I disagree... I can read plugs just fine and did high performance builds and tuning before simple O2s sensors were common. It was a PIA to really know just which air correction jets or emulsions tubes were needed until wide band O2 sensors came onto the scene. Now days if you DON"T use a wide band you deserve whatever happens to your car . I'm a wizard at this and I'll install a wide band BEFORE I put our 75 back on the road. Wide band is far, far more important than a knock sensor. I will not install a knock sensor until I install a complete stand alone digital ECU. At this time I may install more than one knock sensor. Knock sensor saves you when you have a failure. Wide band allows you to actually see the mixture in real time. I've never had a cylinder head temp sensor on anything but they look seriously important and I will add this well before the digital ECU. |
Lo-Fi Version | Time is now: 13th May 2025 - 04:19 PM |
