Wednesday, 20 August 2025 |
| Geezer914 |
Mar 16 2023, 05:03 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,047 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
1975 914. Installed intermittent wiper relay. Wipers worked but would randomly turn on while driving. Removed relay, wipers worked fine on low and high. Check other posts, problem: switch not grounded. So I purchased a VW111.953,519H switch that has the little ground post on the upper right screw. Installed everything, turn on the wipers with the intermittent relay and the wipers do not shut off. Pulled the relay and the wipers only work with the stalk all the way down in the intermittent position and in the off position. If I move the stalk to the low or high position, they do not work. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) It appears I need to switch some wires on the motor. The VW111.953.519H Wiper switch was pictured in a post as the switch needed for intermittent wipers. The diagram is the VW wire diagram for the wiper switch. What is the diagram for a 914? What I am asking is what wires from the motor need to be switched to correspond to this switch?
| KELTY360 |
Mar 16 2023, 05:06 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,152 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
Are you sure the parts weren't made by Lucas? (IMG:style_emoticons/default/shades.gif)
| JeffBowlsby |
Mar 16 2023, 05:28 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,008 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Don;t knw if tis helpds or not, but that diagram on the chassis harness plug is not what I have in my records. I would think that the mating wires on the switch would be the same:
S1 (not 31B) - Brown//black 53 - Black/blue 53e - Green/white 53a - Red/black 53b - Black/purple |
| Geezer914 |
Mar 16 2023, 06:43 PM
On the 914, what does each pin on the switch correspond to the connections on the motor?
| Steve |
Mar 16 2023, 07:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,908 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Weird.. all I did was install a 924 stalk and replace the relay and it worked fine. I wanted the 924 stalk for the electric washer contact. Oh and I had to clip the plastic on the stalk for the intermittent wiper position.
| Geezer914 |
Mar 16 2023, 08:16 PM
What was the part number for the 924 switch?
| Steve |
Mar 16 2023, 09:34 PM
| jim_hoyland |
Mar 17 2023, 05:02 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,852 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Check out:
Windshield Wiper Switch (Front) Part Number: 47795390201C Supersession(s): 477-953-902-01-C; 477-953-902-01C; 477953902 01C |
| Geezer914 |
Mar 17 2023, 08:05 AM
FIXED! Compared the wires in the old switch. Wires were switched on pins 2&3. Swapped the wires and now everything works! (IMG:style_emoticons/default/beerchug.gif)
| Root_Werks |
Mar 17 2023, 08:43 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,765 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Nice!
It's nice to have delay wipers. PO installed the 924/Mk1 setup in my 914. Also have electric washers which is nice. |
| jim_hoyland |
Mar 17 2023, 06:47 PM
While I’ve had the intermittent wiper system for a few years, I really like the Boxters rain sensor. It’s intermittent depending upon the amount of rain. It can really go fast if it starts to pour.
Lo-Fi Version | Time is now: 19th August 2025 - 08:33 PM |
