| 80cap |
Mar 30 2023, 07:50 AM
Member ![]() ![]() Group: Members Posts: 322 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Does the turn signals share the flasher relay?
If not which relay is it? thanks Brian |
| ClayPerrine |
Mar 30 2023, 08:20 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Yes, the turn signal relay is the same as the hazard flasher and brake warning light flasher relay.
Lots of people think it is supposed to be on the back of the fuse panel. It was originally mounted to the dash frame near the headlight/foglight switches. So over the years, it has probably been moved. But it is a square black relay that is about twice as tall as a generic square Bosch relay. |
| 76-914 |
Mar 30 2023, 08:36 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,968 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
If your flashers work the relay is good. If the turn signals aren't working & the flashers are then you have a bad turn signal assume or a faulty connection or burned out lampoon. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th September 2026 - 07:56 PM |
