> 914 wiring worked out but no highbeam
tonybolony
post Apr 13 2023, 05:48 AM
So i have managed to get all the wiring worked out in this 914 i have that was a jumble, i also replaced the fusebox with a more up to date blade fuse box , i have everything working, but no high beams , main beams work, but so the stalk for high beams and the lights go off, so i am guessing its the relay ? can anybody point me to the corrrect light relay, the one on this car is a 4 pin
Replies(1 - 3)
76-914
post Apr 13 2023, 09:13 AM
QUOTE(tonybolony @ Apr 13 2023, 04:48 AM) *
It is most likely the relay. It is easy to bench test it and can be done with a 9v battery and an ohm meter. The newer style replacement relay requires a jumper IIRC. I think Pelican has them. I have one if you can't find one from one of our suppliers. (IMG:style_emoticons/default/beerchug.gif)
dr914@autoatlanta.com
post Apr 13 2023, 10:41 AM
yes relay or replacement new relay not plugged in properly to the harness
tonybolony
post Apr 13 2023, 11:32 AM
thank you for the replays. i am in England , but i have ordered the relay from pelican , the current relay has 4 wires on it so can somebody show me how the 5 pin wires up please ?
- Lo-Fi Version Time is now: 14th April 2026 - 08:42 PM
