| gnomefabtech |
Apr 19 2023, 12:06 PM
Member ![]() ![]() Group: Members Posts: 154 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
Hi-
The patient is a 1976 that has spent some time sitting and the owner lost the ignition key. Is there a way to make an ignition key from the car's VIN? or is there a way to remove the lock cylinder without wrecking anything so I can have it keyed at a lock shop? Thanks |
| StarBear |
Apr 19 2023, 12:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,304 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
| FlacaProductions |
Apr 19 2023, 12:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,226 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
| fiacra |
Apr 19 2023, 12:42 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 734 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
I've been through this before..... Is the key for the ignition different from the door/trunk/frunk/glovebox lock? If you don't have keys for any of those you can simply pull either a door lock or the glovebox lock and take that to a locksmith to have a key made. Unfortunately there is a chance that everything is keyed differently (as it was with my car) and you won't have a key that works with the ignition, although at least now you have a key for the door or glovebox. If they have different keys then you're in a tougher spot. I couldn't find a way to get the cylinder out of the steering column without the key, but maybe someone else here has a trick? I ended up having a mobile locksmith come out and make a key. It cost $150. It was worth it. Good luck!
| rhodyguy |
Apr 19 2023, 12:59 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I used a mobile locksmith once. Watched him ‘read’ the cyl with a soft blank then matched it and cut a new one. Insurance covered the ‘lockout’. I did not have to take anything apart.
| TheCabinetmaker |
Apr 19 2023, 01:58 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Vin will not provide the key code. I would suggest you pull the front trunk lock and send it to me. It's the easiest to remove.
I can make you a generic key for $45.00. front trunk locks are the most likely to match the ignition. 75 model ignitions are difficult to remove. Please take a pic of the ignition so I can determine if your ignition is still original. A local locksmith will cost you 150.00-200.00. |
| gnomefabtech |
Apr 19 2023, 04:32 PM
Thanks for the replies.
I tried all the keys that the owner has and they for sure don't fit the ignition. I'll see if I can pull the front trunk lock and send it to you Mr Cabinetmaker. The car is a 76. Is that still a tough one to remove? |
| 76-914 |
Apr 19 2023, 04:36 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,892 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
yep. 75 & 76 are the same car.
| davep |
Apr 19 2023, 07:59 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,363 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
| ClayPerrine |
Apr 20 2023, 08:09 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,545 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
A lot of 914s had the ignition locks replaced with VW units. It uses a completely different key that will not fit any other locks on the car.
Original: ![]() Later replacement: ![]() This lock was used on the 924 and all the VW products of that era. The lock mechanism was the same, so it superseded the original lock in the parts catalog. You can find people on here who have the 914 locks used and get it rekeyed to to work with the rest of the locks. |
| Jason74914 |
Apr 20 2023, 12:21 PM
Member ![]() ![]() Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None |
keys4classics can make a key from picture of key by email
| TheCabinetmaker |
Apr 21 2023, 10:35 AM
[quote name='Jason74914' date='Apr 20 2023, 01:21 PM' post='3072643']
keys4classics can make a key from picture of key by email [/quote I can do that too. |
| TheCabinetmaker |
Apr 21 2023, 10:40 AM
Thanks for the replies. I tried all the keys that the owner has and they for sure don't fit the ignition. I'll see if I can pull the front trunk lock and send it to you Mr Cabinetmaker. The car is a 76. Is that still a tough one to remove? Send me an email at cbntmkr at Gmail dot com and we'll chat. |
| dr914@autoatlanta.com |
Apr 21 2023, 11:04 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,239 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
call your dealer, they have codes from 72 on but you will have to probably get their regional service manager involved.
| TheCabinetmaker |
Apr 21 2023, 02:22 PM
I tried thats a couple of years ago George. They wouldn't talk to me unless I was a certified member of the national locksmith association.
Lo-Fi Version | Time is now: 7th June 2026 - 12:53 PM |
