Super penetrating oil |
sixaddict |
May 1 2023, 05:31 PM
Senior Member Group: Members Posts: 806 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
brant |
May 1 2023, 05:43 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Have you used kroil?
Hard to believe anything is better than kroil |
technicalninja |
May 1 2023, 06:06 PM
Senior Member Group: Members Posts: 1,368 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
"Pimp Juice" is my go-to now for ferrous metals.
1/2 acetone 1/2 Dexron III Shake it up before use. The acetone separates during storage. Works so much better than anything else on ferrous fasteners. Dissimilar metals? I use wintergreen oil. You by this on Amazon as an "essential oil" The wintergreen oil was a tip from military techs servicing aircraft on carriers. Just imagine... Every single fastener has multiple dissimilar metals touching each other and it's being used in a "salt" poisoned atmosphere. |
sixaddict |
May 1 2023, 07:22 PM
I have not but a tic-tac-toe video co mpared t he two….I believe this won but can’t attest.
[code] name='brant' date='May 1 2023, 03:43 PM' post='3075102'] Have you used kroil? Hard to believe anything is better than kroil [/quote] |
bkrantz |
May 1 2023, 08:51 PM
914 Guru Group: Members Posts: 7,811 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
bkrantz |
May 1 2023, 08:52 PM
VaccaRabite |
May 2 2023, 05:10 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
"Pimp Juice" is my go-to now for ferrous metals. 1/2 acetone 1/2 Dexron III Shake it up before use. The acetone separates during storage. Works so much better than anything else on ferrous fasteners. Dissimilar metals? I use wintergreen oil. You by this on Amazon as an "essential oil" The wintergreen oil was a tip from military techs servicing aircraft on carriers. Just imagine... Every single fastener has multiple dissimilar metals touching each other and it's being used in a "salt" poisoned atmosphere. Yup. Acetone and ATF has been my go-to for years. Way better then Kroil. Zach |
Superhawk996 |
May 2 2023, 07:17 AM
914 Guru Group: Members Posts: 5,913 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Dissimilar metals? I use wintergreen oil. You by this on Amazon as an "essential oil" The wintergreen oil was a tip from military techs servicing aircraft on carriers. Just imagine... Every single fastener has multiple dissimilar metals touching each other and it's being used in a "salt" poisoned atmosphere. Can’t imagine the military using anything other than $1000/can Mil-spec stuff. Hell; I used to have the recipe for MRE brownies - it was something like a mind numbing Now don’t get me wrong, I’ve never tried wintergreen oil. But, I will give it a try! I’m also not saying some yahoo isn’t putting wintergreen oil purchased off Amazon from the Chinese, putting it in a can, and slapping a MIL-Spec label on it and then selling it to military procurement (IMG:style_emoticons/default/av-943.gif) |
brant |
May 2 2023, 07:26 AM
Going to try the wintergreen also
Ordered it last night Thanks for the tip |
NARP74 |
May 2 2023, 08:05 AM
Senior Member Group: Members Posts: 1,075 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
This needs a shootout style competition. I just read about Free All being good, from amazon. I have usually been less than impressed with blaster, which is available everywhere, and wd40 never did much for me either.
technicalninja |
May 2 2023, 08:26 AM
makes your shop smell like Christmas!
I found an "off prescription" use of the wintergreen oil this last winter. I ended up with a "puss" catapillar infestation on the bush by my shops front door. I always called these things "asps" as they can still the crap out of you. These critters have poison "hairs" like a jellyfish. I've never seen more than one before and my bush had hundreds! They ate more than 1/3 of the foliage in a very short time. These things are hard to kill and eradicate. They make a special "BT" poison that works great but took 8 days to get here. The internet said "essential oils like peppermint can be a pesticide." I didn't have peppermint but the wintergreen oil made them MELT in about 20 seconds... It's MAGICAL on killing caterpillars... A single drop is all you need! |
DennisV |
May 2 2023, 08:34 AM
Member Group: Members Posts: 495 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Have you used kroil? Hard to believe anything is better than kroil I used Kroil for a long time, but switched to Sea Foam Deep Creep after my dad showed it to me. It really does foam up a bit and clings to surfaces better than Kroil. Which is helpful if you have something other than a horizontal surface. I'm sure everyone has a favorite, and there is probably a 10 page argument on Garage Journal somewhere. I don't have a dog in the hunt. Just sharing. |
technicalninja |
May 2 2023, 08:45 AM
I use a shit ton of WD40.
I call it my dis-assembly fluid. All plastic pop clips and any electrical connection will come apart much easier and be re-usable. It is the proper lubricant for the internal seals in a weather pack style fitting. WD40 doesn't damage stuff like the pimp juice will. I don't use it for assembly, but it is integral to my work. I don't use it at all for jammed fasteners in metals... |
eeyore |
May 2 2023, 09:43 AM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
NARP74 |
May 2 2023, 10:01 AM
Not the result I was expecting |
brant |
May 2 2023, 10:04 AM
I've never had good luck with liquid wrench though....
rhodyguy |
May 2 2023, 10:13 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Amazon. I NEVER read the positive reviews. The straight poop is in the ones that usually describe the numerous flaws and shoddy quality.
How much lacquer thinner do you buy at a time? A gallon? AeroKroil is a great product. Convenient spray can. No mix, no mess, no nitrile gloves. Like most penetrants it can take time and multiple applications. Water Displacement formula #40. |
StarBear |
May 2 2023, 11:13 AM
Senior Member Group: Members Posts: 1,917 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
A worthwhile video and well-done experiment. Not exhaustive, for sure, but good technique. Thanks! |
76-914 |
May 2 2023, 01:07 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,512 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I use a shit ton of WD40. I call it my dis-assembly fluid. All plastic pop clips and any electrical connection will come apart much easier and be re-usable. It is the proper lubricant for the internal seals in a weather pack style fitting. WD40 doesn't damage stuff like the pimp juice will. I don't use it for assembly, but it is integral to my work. I don't use it at all for jammed fasteners in metals... Good to know! |
sixaddict |
May 3 2023, 05:27 PM
Help.
Two STUCK studs. Used heat, special Collette tool, impact wrench and tapping. 3 days still no luck. Ideas?.. |
Lo-Fi Version | Time is now: 14th June 2024 - 04:46 AM |
