Has anyone side gapped their spark plugs?, Does it make any difference? |
oakdalecurtis |
May 6 2023, 12:23 PM
Oakdalecurtis Group: Members Posts: 1,328 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
SirAndy |
May 6 2023, 12:28 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Works best when combined with an intake vortex generator ...
(IMG:style_emoticons/default/shades.gif) |
oakdalecurtis |
May 6 2023, 01:05 PM
Works best when combined with an intake vortex generator ... (IMG:style_emoticons/default/shades.gif) At first blush I thought “side gapping” was a new kind of Kama Sutra position to get more spark….. |
Superhawk996 |
May 6 2023, 01:11 PM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Also works great to shorten spark plug life by forcing all electrode errosion to a much smaller portion of the electrode.
SirAndy |
May 6 2023, 02:22 PM
Also works great to shorten spark plug life by forcing all electrode errosion to a much smaller portion of the electrode. On the plus side, now that the compression stroke has a much better chance to blow out the spark, you'll get about the same amount of erosion over the lifetime of the spark plug. (IMG:style_emoticons/default/w00t.gif) |
emerygt350 |
May 6 2023, 02:25 PM
Advanced Member Group: Members Posts: 2,147 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would have to suspect after 130 years of spark plug development there is a reason they don't come like that from the factory.
r_towle |
May 6 2023, 02:31 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Works best when combined with an intake vortex generator ... (IMG:style_emoticons/default/shades.gif) At first blush I thought “side gapping” was a new kind of Kama Sutra position to get more spark….. You go down this road so fast …. |
brant |
May 6 2023, 03:05 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Indexing makes more sense to me
live free & drive |
May 6 2023, 03:48 PM
Member Group: Members Posts: 159 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
Many Alfa engines require 4 side electrode spark plugs like these:
https://teka-alfaparts.nl/teka-alfaparts-we...lugs-605045630/ These have typically been perfectly hemispherical chambers with the plug in the top center |
ClayPerrine |
May 6 2023, 04:50 PM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 964 motor uses plugs like this from the factory:
It comes pre-gapped. (IMG:style_emoticons/default/smile.gif) |
r_towle |
May 6 2023, 05:10 PM
I tried those once on my 914.
They performed worse, then Capn yelled at me. |
worn |
May 6 2023, 06:03 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
BeatNavy |
May 6 2023, 06:27 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
fixer34 |
May 6 2023, 08:22 PM
Senior Member Group: Members Posts: 1,090 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
The 964 motor uses plugs like this from the factory: It comes pre-gapped. (IMG:style_emoticons/default/smile.gif) Long time ago, JC Whitney sold something they called Fire Injector plugs. Similar idea but the outer ground was almost a full circle with the electrode in the center. |
Garland |
May 6 2023, 10:35 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
mlindner |
May 7 2023, 05:25 AM
Senior Member Group: Members Posts: 1,529 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Thats to cool Garland. Look at the list of car's, so many not around any more. But we still have the Singer! AND now you can Charge you Order. Thanks, Mark
technicalninja |
May 7 2023, 12:32 PM
Senior Member Group: Members Posts: 1,343 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Side gap and surface discharge have been around forever...
First surface discharge I hit was way back in the 70s. Mazda rotary required exotic plugs and about 3 times the energy to fire. The plugs with 3 or 4 electrodes just give multiple paths for the spark. Each time it fires it only fires to a single electrode, not multiple sparks to each electrode as the packaging often depicts. Having 4 electrodes mean as the gap increases on one it becomes easier to make the jump to another electrode and the "gap" increases very slowly over the course of the plugs life. Those 964 plugs will slowly "square off" the center electrode as it moves to each side ground strap over the course of its life. Iridium plugs changed all of this... The multiple electrodes are for extended life and nothing else. Iridium life span for a single electrode made the multi-electrode plug a thing of the past. BMW was big on multiple electrodes and current thinking has everyone using NGK iridiums. Do to the clearance inside a rotary the surface discharge is still the way to go (and multiple electrodes if original). I haven't been active in the rotary world so long that I do not know if iridium is available in a rotary plug. I would not modify an iridium plug but I have cut down the ground electrode to allow better flame propagation from the spark kernel on copper stuff. By the time I'm modifying the ground strap I'm already "indexed" with the opening facing the largest section of the combustion chamber and "cheated" towards the exhaust valve. Side gapping a plug is never, never about longevity. At this level of preparation, the plugs will be consumables automatically replaced at much lower intervals than something I'm using in a road car (which needs to live 50K IMO). Side gapping and modifying plugs will not do jack diddly shit to a stock or mildly modified ICE engine. My recommendation is a Iridium single strap resistor plug. NGK often has "iridium" and "laser Iridium"... No lasers are used during the making but the ground strap of the "laser" is significantly cut back and pointed to unmask the spark kernel as much is possible. This "mod" adds 50% to the cost of the plug and is un-needed IMO. I'm a "non-laser" guy... |
PatMc |
May 8 2023, 11:07 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
home made splitfires! lol
Used to just snip the ground strap back with a pair of dikes so it only overlapped about 1/2 the center electrode....worked OK to help with fouling on engines that should have been rebuilt 50K miles ago. |
Root_Werks |
May 8 2023, 12:01 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Some aircraft use "side discharge" plugs. I ran Bosch DTC's in T4's, 911's and Bugs before. Never really noticed any difference.
Dunno why W7DTC is stuck in my head, here's a link for example: https://www.zoro.com/bosch-w7dtcspark-plug-...ByABEgJRwfD_BwE |
Lo-Fi Version | Time is now: 10th June 2024 - 12:47 AM |
