Dual 40 IDF'S really weird . . . ., defective Spanish casting???? |
ghettojet |
May 14 2023, 08:44 PM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
1.8 engine rebuilt by me.New Weber IDF's from CB Performance.
Engine is being bench run Fuel pressure 3.0lb,even tried a little less at one point. Good strong spark all around Timing is on. No gas in idle circuit cylinders #1 & 4 Mixture screws on this carb have no effect took apart carb,blew air through idle jet passages double checked float height. all good. Compression good engine has a few hours on it Finally I swapped carbs Problem follows the carb Now #2 & 3 not "participating" air correction 2.00 emulsion tubeF-11 Main 1.15 Idle .50 Venturi 28mm Only thing I can think here is that the actual casting is defective internally? Seems far fetched Am I missing something? not sure what I can do except return carb to CB Performance Would rather not do this Please advise |
Superhawk996 |
May 14 2023, 09:50 PM
914 Guru Group: Members Posts: 5,908 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
This is a confusing post to me . . . But maybe I’m not reading it right. Cylinders #1 and #4 are on opposite cylinder banks.
Do you have problems with one carb or both? Have you verified all air bypass screws are closed? An air bypass that is too far open will completely negate the idle circuit for that barrel that has the air bypass open too far. You say idle circuits aren’t getting gas - based on what? What are the symptoms? Sort of sounds like you’re implying the engine is only running on two cylinders? If so how did you verify that it is only running on two cylinders? What has been done to balance airflow and synchronize the carbs? Are you trying to tune with all linkages connected? Just not enough info to address your question |
r_towle |
May 14 2023, 10:20 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
“engine has a few hours on it”
How is that possible? |
Front yard mechanic |
May 15 2023, 05:48 AM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Take them apart again and make sure to check float levels. Remove all and reassemble them I’ll bet it is clogged somewhere. The lube they use when they assemble them new dries up and turns gummy bear.
Lo-Fi Version | Time is now: 13th June 2024 - 05:32 AM |
