r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I’m going to build a flat 8.
Not asking to debate this, but it’s the premise of my current research. In the only successful motor built like this, in Brazil in the 70s or 80s, they had issues getting oil at sufficient pressure to the crank/valves furthest away from the pump. So, I have two ideas. If you look at the 911, there is an external oil feed pumping oil into the valve train. I’m thinking of something like that, but not sure how to route it, or the right place to inject oil ….maybe at the beginning of the second case….or the other end and feed it backwards. Or I could enlarge the internal oil galley in the first motor to increase volume. I expect I will need to find the highest volume pump I can. I assume different pressure relief valves. I assume eternal oil cooler and filter. The rest of the architecture looks fairly straight forward. I need help, experience, and some hotrod thinking on the oil issue. |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
If I was building a POC (proof of concept) engine I'd simplify the oil system routing by taking it external and running a dedicated dry sump system.
These are commonly driven by a small gilmer belt and are stacked units. I've seen dry sump pumps with 2 pressure sections and 5 scavenge sections. You can set up whatever you wish and change stuff around easily if needed. The only downside is added complexity of the external lines and the overall cost. Building a flat eight out of two different engines will be harder than building a H8 case (billet aluminum would be my choice) in the first place. I would expect this to be an expensive endeavor. Far more expensive than buying a 3.6 and a 915 gear box... Far more expensive than adapting a Ferrari V8... Far more expensive than fitting a twin turbo Bently W12 and PDK... Would definitely be at or above the same level of WOW as the above. I bet a custom H8 crank would be 50K from a reputable crank builder if you could find one that would try. It would still be very neat to see someone do this. Water pumper or air cooled? NA or boosted? What vehicle do you plan on installing this in? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,954 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I would go to someone making billet type 1 engines and see if they could add cylinders. Then do the same with the crank. Won’t be cheap but if it can be done, it won’t be starting from scratch.
I would think it’s more of a Jay Leno type of project or someone who has a couple 100k to throw at a whimsical project. |
r_towle |
Welding two cases together is proven.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,168 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
I have an extra F355 engine collecting dust if anyone is interested
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,199 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I have an extra F355 engine collecting dust if anyone is interested Since it’s in your way . . . Just send it to me, I’ll “store” it for you (IMG:style_emoticons/default/happy11.gif) With respect to OPs post - I wish you the best of luck - what you’re contemplating is no small task. I’d suggest you look into old dragsters of the 60s. There were quite a few Siamese’d engines tried in dragsters back then. |
VolksSled |
Newbie ![]() Group: Members Posts: 28 Joined: 3-May 23 From: California Member No.: 27,331 Region Association: Southern California ![]() |
Welding two cases together is proven. For once I agree with this guy And theses guys …. https://oldmachinepress.com/2021/07/20/daim...-doppelmotoren/ (IMG:style_emoticons/default/flag.gif) |
r_towle |
Attached image(s) ![]() ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
OHC or pushrod-actuated valves? Two flat-fours, or a couple of sectioned flat-sixes? Or going water-cooled?
Realistically, to get the oil where it needs to go you will probably have to re-engineer the whole oiling system. technicalninja's suggestion of running external lines to where you need the oil is probably the easiest and most straight-forward way to do it. Adequate cooling will also be an interesting challenge. --DD |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,292 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
So the first picture looks like they just bolted 2 engines together, nose of one to the flywheel end of the other. Each case in that situation has its own oil system.
I'm guessing you are going for the second picture where you weld 2 cases together with a filler piece from a third. Happened to be at an indoor sport complex today and saw exactly what you need to deal with. The overhead ventilation system starts with a very large pipe and then gradually decreases in size as it extends further into the building. The question is, can you increase the pump intake, flow, and size of the front block oil galleries/passages enough? They are what, 11-12mm now? Rough calculations (area) you need to enlarge them to about 17mm. |
r_towle |
So the first picture looks like they just bolted 2 engines together, nose of one to the flywheel end of the other. Each case in that situation has its own oil system. I'm guessing you are going for the second picture where you weld 2 cases together with a filler piece from a third. Happened to be at an indoor sport complex today and saw exactly what you need to deal with. The overhead ventilation system starts with a very large pipe and then gradually decreases in size as it extends further into the building. The question is, can you increase the pump intake, flow, and size of the front block oil galleries/passages enough? They are what, 11-12mm now? Rough calculations (area) you need to enlarge them to about 17mm. Getting closer. What are the inputs to know what is correct? If you notice the last picture, this is 1/2 of the welded case while they were trying to figure out how to increase oil pressure . External, dry sump, can be done External pump, ok External cooling ok Now where to inject oil….hmm |
r_towle |
This video, and complete story, makes me inspired to do this, yet use new tech to solve some issues.
Listen to this… https://m.youtube.com/watch?v=tXKcpbFF7WI&a...ature=emb_title |
930cabman |
Good luck with this project, not for the meek by any stretch. Also, if the factory did it, I'm sure it can be done again. Just a mountain of $$$
Lo-Fi Version | Time is now: 3rd July 2025 - 01:27 PM |
