| VaccaRabite |
Jun 3 2023, 07:56 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,939 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I have never pulled an exhaust stud before while doing pipes. This evening I’m 4 for 4. These copper flanged nuts locked on the studs and there was 100% no getting them off without the studs coming with them. Going back to using just regular nuts with 12mm flats. So much for trying to get the “right” part. Edit to add details: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976726.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1685976727.2.jpg) The nuts in question are commonly available and sold as exhaust nuts. I got mine from Auto Atlanta - but many places sell them. The have a copper color to them and the bore is slightly oval. The are designed to lock on to the stud - which I did not know at the time. They go on tight and you can not remove them without pulling the stud. There are flanged nuts that work fine. Kinda furious with myself right now. Continuing to live life as an object lesson for others… Zach |
| bkrantz |
Jun 3 2023, 08:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,816 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Did you use anti-seize?
| VaccaRabite |
Jun 3 2023, 08:22 PM
| mgphoto |
Jun 3 2023, 08:23 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,509 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
| VaccaRabite |
Jun 3 2023, 08:26 PM
Car started popping a lot on decel today while I was driving around. So, exhaust leak. Once on the lift I found the #4 pipe had cracked at the ears.
Once I got the pipe down, the crack went 3/4 of the way around the entire circumference of the pipe! I was going to weld it, but it’s an older set of SSIs I got used. I don’t know that they are worth welding. Thoughts? Zach |
| mgphoto |
Jun 3 2023, 09:09 PM
Car started popping a lot on decel today while I was driving around. So, exhaust leak. Once on the lift I found the #4 pipe had cracked at the ears. Once I got the pipe down, the crack went 3/4 of the way around the entire circumference of the pipe! I was going to weld it, but it’s an older set of SSIs I got used. I don’t know that they are worth welding. Thoughts? Zach Tig is best, you need to flood the inside of the pipe with the shielding gas to prevent oxygen from attacking the weld. |
| r_towle |
Jun 3 2023, 09:15 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Or
Headers and exhaust from Foley? |
| VaccaRabite |
Jun 3 2023, 09:37 PM
| r_towle |
Jun 3 2023, 11:01 PM
I thought it had heat?
If you are jammed I will go take a look in the barn Which side/version do you need? 1.7 or 2.0 liter boxes? Remind me…which one curves up? I have at least two spare sets… Rich |
| mepstein |
Jun 4 2023, 04:35 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,994 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| ClayPerrine |
Jun 4 2023, 06:53 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
There is an Aluminized Mercedes Benz flanged exhaust manifold nut that works great. They stay tight, but don't seize to the stud, and the flange means you can get a socket on them.
I don't have the part number but @partsguy22 will know. Clay |
| rhodyguy |
Jun 4 2023, 07:08 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are those the VW style ones? With the slightly oval (that seizes the stud) hole? MOM on the stud helps.
| rhodyguy |
Jun 4 2023, 09:08 AM
I think you will find 8 of these more to your liking.
Attached thumbnail(s) |
| sixnotfour |
Jun 4 2023, 09:24 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,425 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Im not a type 4 guy , But Ive seen more cracked SSI's than good ones...
In Fact I have a perfect set appearance wise.. and are cracked exactly as Zacs are.. |
| rhodyguy |
Jun 4 2023, 09:30 AM
Torqueing the shit out of the nuts, to cure a leak, is a sure fire way to tear the ears off. Take them up 5#s at a time, to 20#s, in an X pattern. You don’t want to build in a leak from the git go.
| JamesM |
Jun 4 2023, 01:35 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I think you will find 8 of these more to your liking. (IMG:style_emoticons/default/agree.gif) Those ACN 10mm flange nuts are the ticket! I use them for almost everything now I learned the hard way with those copper nuts like 15 or so years ago. Not sure why vendors still sell them, they are the absolute worst |
| DC_neun_vierzehn |
Jun 4 2023, 03:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 693 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I think you will find 8 of these more to your liking. (IMG:style_emoticons/default/agree.gif) Those ACN 10mm flange nuts are the ticket! I use them for almost everything now I learned the hard way with those copper nuts like 15 or so years ago. Not sure why vendors still sell them, they are the absolute worst Are these what y'all are talking about? https://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm |
| sixnotfour |
Jun 4 2023, 03:53 PM
I think you will find 8 of these more to your liking. (IMG:style_emoticons/default/agree.gif) Those ACN 10mm flange nuts are the ticket! I use them for almost everything now I learned the hard way with those copper nuts like 15 or so years ago. Not sure why vendors still sell them, they are the absolute worst Are these what y'all are talking about? https://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm yup @Rhodyguy has a bunch,, hit him up... I got 100 from him.. |
| VaccaRabite |
Jun 4 2023, 06:51 PM
Torqueing the shit out of the nuts, to cure a leak, is a sure fire way to tear the ears off. Take them up 5#s at a time, to 20#s, in an X pattern. You don’t want to build in a leak from the git go. I always use a 1/4 inch mini-driver on the exhaust nuts to try and avoid this. All the used SSIs being old and heat cycled a million times does not help. And those fucking flanged pinch nuts are so tight that they throw the torque settings way off. Lessons learned - a couple of them. Zach |
| porschetub |
Jun 4 2023, 07:34 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,200 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
There is an Aluminized Mercedes Benz flanged exhaust manifold nut that works great. They stay tight, but don't seize to the stud, and the flange means you can get a socket on them. I don't have the part number but @partsguy22 will know. Clay (IMG:style_emoticons/default/agree.gif) used the BMW version of these on my "6" headers ,really good and don't loosen up , got them from Pelican for chump change each,seem to remember brass and steel don't play well together due to constant heat cycling. After extracting 4 bad head exhaust studs I wasn't prepared to use the wrong nuts..end of story. |
Lo-Fi Version | Time is now: 13th November 2026 - 12:36 PM |
